Help with ggi interfaces
Old   November 4, 2010, 17:34
Default Help with ggi interfaces
kalyan
hardykalyan is on a distinguished road
Can some one suggest me a method or a possible way to work on problem having non matching grids at one place and also need to have a rotatory model at an other end.
Searched and found that ggi handles both the problems. I cannot find the actual details of ggi and so can someone suggest me how to handle the two problems i have stated above.
Best regards,
hardykalyan is offline   Reply With Quote
Old   November 6, 2010, 12:26
kalyan
Can someone tell me if i can use different rotating velocities to two different regions at the same time in ggi.
Old   November 6, 2010, 12:55
Martin Beaudoin
mbeaudoin will become famous soon enough
This has nothing to do with the GGI interface.
The GGI interface is just a "transfer function" for interpolating flow values across non-matching patches.
What you need is a solver that will support different rotating velocities in different regions. For this, you need a solver that will support Multiple Reference Frames.
Martin
mbeaudoin is offline   Reply With Quote
Old   November 6, 2010, 14:47
kalyan
Thanks Martin, But can you suggest me some solvers for this case ? And the other question is, in the DynamicMeshDict file we define the velocity(RPM) in ggi case, but if i want two have two different velocities for different regions?
Ggi FabOr OpenFOAM 17 May 9, 2013 10:19
Difference between ggi and overlapGgi? GGI Tips and Tricks? philippose OpenFOAM Running, Solving & CFD 7 January 16, 2013 09:40
GGI in OpenFOAM-1.5-dev philippose OpenFOAM Running, Solving & CFD 14 November 13, 2011 14:55
GGI Interfaces pippi OpenFOAM 0 September 15, 2010 04:05
problem with GGI interfaces strider CFX 6 May 29, 2006 14:20
