Artificial compressibility in open foam
Like Tree1Likes
Old   April 3, 2012, 01:14
G. D. McBain
gdmcbain is on a distinguished road
Dear Gilles,
This is quite a good idea; I believe artificial compressibility may even have originally been developed as a false-transient method of enforcing incompressibility (though I don't have access to Chorin's paper at the moment).
While it might be possible to adapt and re-use the infrastructure of class ddt as commonly used in the transient solvers distributed with OpenFOAM, such as laplacianFOAM, that wouldn't be necessary in this case. Instead, I presume one would really only contemplate using backward-Euler integration for the false transient, so all that would be required is to set up two lots of variables for the unknowns, e.g. add pold for the pressure, defined just like your original pressure variable. Then formulate the backward-Euler step equation for your pseudo-time, and each pseudo-timestep, solve these for the new unknowns in terms of the old and then copy the new to the old, repeating till converged within a tolerance (or whatever). Implement this as a standard C++ while-loop, inside the real time-stepping loop. (Again, there are facilities in the OpenFOAM library to support iteration, but it's by no means necessary to use them if you haven't learned them, as nothing too complicated is required here.)
Hope this helps.
gdmcbain is offline   Reply With Quote
Old   March 27, 2018, 09:17
Default Artificial Compressibility
  #22
Stefan
soletto is on a distinguished road
Can anyone explain me for noobs what is artificial compressibility?
lg
Stefan
soletto is offline   Reply With Quote
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
