[snappyHexMesh] scotch error on motorbike on 16p
Like Tree1Likes
  • 1 Post By dkokron
Old   December 24, 2012, 20:53
Default scotch error on motorbike on 16p
Dan Kokron
dkokron is on a distinguished road
All,
I received the following error from scotch-5.1.11 when running snappyHexMesh using 16 processors on the incompressible/pisoFoam/les/motorBike tutorial. The 8p case ran fine out-of-the-box.
"dgraphFoldComm: internal error (3)"
This error emanates from line 307 of ThirdParty-2.1.x/scotch_5.1.11/src/libscotch/dgraph_fold_comm.c
I reviewed the code from newer versions of scotch and found significant changes between 5.1.11 and 5.1.12 for this same file. I installed scotch-5.1.12b and sure enough, snappyHexMesh ran fine on 16p. I reran the 8p case to see if the new scotch changes the results significantly. The mesh started to diverge after a few iterations, but the final drag coefficients agreed within the first decimal place. Close enough for me.
I also tried the scotch-6.0.0 release, but snappyHexMesh failed at run time with an unresolved symbol.
Hope this helps.
Dan
wyldckat likes this.
dkokron is offline   Reply With Quote
Old   December 27, 2012, 06:01
Retired Super Moderator
Bruno Santos
Greetings Dan and welcome to the forum!
Many thanks for sharing this information! Now I understand better why this bug report was made a year ago: http://www.openfoam.org/mantisbt/view.php?id=355
Hopefully in the next major release of OpenFOAM, they'll update the Scotch library version.
Best regards,
Bruno
[OpenFOAM.org] Install OpenFOAM 2.4.x using system Scotch cbcoutinho OpenFOAM Installation 7 October 16, 2019 19:12
[snappyHexMesh] Trying to understand the motorBike tutorial Andyjoe OpenFOAM Meshing & Mesh Conversion 10 August 10, 2014 16:57
scotch or ptscotch? cfdonline2mohsen OpenFOAM 6 July 3, 2013 13:17
[snappyHexMesh] Editing the motorBike case, loading diffirent .stl btgyd OpenFOAM Meshing & Mesh Conversion 1 September 26, 2011 17:24
Problem with Scotch in 1.7.x? dancfd OpenFOAM Running, Solving & CFD 0 June 15, 2011 21:52
