cantera-1.7.0 ,openfoam1.7.1
Old   January 15, 2011, 09:48
Default cantera-1.7.0 ,openfoam1.7.1
Farshad
Farshad_Noravesh is on a distinguished road
Hi ,
I have attached my errors after i moved all necessary source files in hannes repository from libextensions to generateFGM folder in order to generate the flamelet lookupt table after successful compilation.
please help me,
Thanks,
Farshad
Farshad_Noravesh is offline   Reply With Quote
Old   January 15, 2011, 21:15
Retired Super Moderator
Bruno Santos
Greetings Farshad,
Although I would like to at least help you out with the build process, I have no clue as to what steps you have taken to get to the point you got to get that output you posted.
If you can detail a bit the steps you've taken for getting the files you are using, how you are trying to build them and with which OpenFOAM version, perhaps I can at least help out with the build process.
Best regards,
Bruno
Cantera hellorishi OpenFOAM Running, Solving & CFD 112 September 28, 2016 08:57
OpenFOAM 1.7.0 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 1 May 26, 2011 03:09
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x wyldckat OpenFOAM Bugs 18 October 21, 2010 05:51
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
interFoam 1.7.0: continuityErrs.H in PSIO loop idrama OpenFOAM 1 July 8, 2010 02:56
