how to define the two different constant properties?
Old   January 24, 2011, 09:28
Smile how to define the two different constant properties?
Alpesh
alvora is on a distinguished road
Hello friends,
In one domain, I have to two different phase and I want to specify the constant physical properties which are different for each phase. can I define the physical properties for each phase separate?
as example: the one metal sphere and air are in cube box. the conductivity of both, sphere and air, are different. So, How I can specify the conductivity for two different phase?
Kind regards
Alpesh
alvora is offline   Reply With Quote
Old   January 24, 2011, 09:49
Bernhard
Bernhard is on a distinguished road
You can either define them as two different constants in your transportProperties, which you read somewhere in your solver. You can also change the twoPhaseMixture class to handle an additional constant, but you still have to define it in your inputfiles somewhere, unless you want it hardcoded in your solver...
Bernhard is offline   Reply With Quote
Old   January 24, 2011, 13:50
Alpesh
Thank you very much for reply sir Bernhard
Chemical properties that are used in Fluent kimej FLUENT 4 August 19, 2011 11:29
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 09:23
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
