Plot of the turbulent viscosity
Old   February 22, 2011, 07:03
Default Plot of the turbulent viscosity
Girolamo
lift86 is on a distinguished road
i would like to plot with parafoam the turbolent viscosity on my Omera M6 wing.
I made a case with the Spalart-Allmaras turbolent model and i can obtain the plot of the nut easily.
now i'm trying to use the k-omega model, but in parafoam i have nut=0 so i don't have any plot.
which parameter should I choose to view the turbolent viscosity on my wing???
thanks very much
p.s. i have also u=0 in the paraview menu!!!
lift86 is offline   Reply With Quote
Old   February 26, 2011, 05:17
Claus Meister
idrama is on a distinguished road
On the Wing (Wall) itself are these values zero: nut - because of the boundary layer and U by definition.
idrama is offline   Reply With Quote
Old   February 26, 2011, 15:00
Girolamo
ok, thanks
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet Felipeb Main CFD Forum 1 July 26, 2010 17:02
Turbulent viscosity and shear rate shib FLUENT 0 June 22, 2010 12:44
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
