Defining additionally variables of U in OF 1.6
Old   March 3, 2011, 07:44
Default Defining additionally variables of U in OF 1.6
sirLentschi
lentschi is on a distinguished road
I am an OF Newbie and want to set up a case of a pump turbine in OF 1.6.
Therefor I have to integrate some additionally variables of the Velocity in 3 different local coordinate systems, such as:
U_new1=Ux*cos(10°)+Uy*sin(10°)
U_new2=Ux*cos(12°)+Uy*sin(12°)
U_new3=Ux*cos(30°)+Uy*sin(30°)
Can anyone tell me, where I have to define this 3 velocities and in which Script I have to perform this Integration?
Or do you think it's better to output the standard Velocity U and transform it later during post?
Thanks in advance.
Regards Markus
lentschi is offline   Reply With Quote
Old   March 5, 2011, 07:51
Gijsbert Wierink
gwierink is on a distinguished road
Hi Markus,
The x-component of a field, here U, is U.component(0). The y- and z-components would be U.component(1) and U.component(2), respectively. Now, the way you have written it gives a volScalarField, not a volVectorField (like U itself). For instance, you could plug the following in the solver after U is solved:
scalar angle1 = mathematicalConstant::pi/6.0;
volScalarField Unew =
    U.component(0) * Foam::cos(angle1)
 + U.component(1) * Foam::sin(angle1);
This calculates a field of scalars that consist of Ux*cos(pi/6) + Uy*sin(pi/6), where cos and sin use rad. But the field is not written every time step. For that you need to put
Info << "Reading field Unew\n" << endl;
volScalarField Unew
    IOobject
        "Unew",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ,
        IOobject::AUTO_WRITE
    mesh
in createFields.H. Then, you don't need to specify the type of Unew in the code, i.e. leave out "volScalarField" in the code that calculates Unew. If you use "MUST_READ" in createFields.H you need to make a file in the 0 folder of the case, where the initial and boundary conditions of Unew are specified.
If you'd like to write every time step, function objects are handy. In your case probably the turboPerformance function objects. Hope this helps you on your way a bit!
Regards, Gijs
gwierink is offline   Reply With Quote
Old   March 7, 2011, 08:56
sirLentschi
Hy Gijsbert,
thank you very much for your instruction!Now, I have to think about if it's necessary to perfom the transformation during solving - in my opinion this may rise the calculation time?!
For this reason I think it's much easier to output only the velocity U and to create a script in python during post,which transform it to local coordinate systems.
Regards Markus
Old   March 7, 2011, 09:10
Gijsbert Wierink
Hi Markus,
Sure, the calculation, although small, will take some time. You could use the U file in the time step directories. This, however, only gives you data at write time. If you need data at every time step I suggest to either use a function object or put the above code in and write out the data in an info statement to a log file. For that simply add
Info << "Unew = " << Unew << endl;
to the solver, run the solver with
somethingFoam > log &
and grep Unew from the log file.
Regards, Gijs
Accessing other variables in defining boundary condition Cynthia Poon OpenFOAM Running, Solving & CFD 1 September 27, 2021 06:28
k-omega-SST model (OF 1.6) - turbulent flat plate cboss OpenFOAM Running, Solving & CFD 25 August 9, 2016 09:53
Defining New Variables Tim Phoenics 0 September 30, 2003 14:52
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
Saving variables on a user patch with physical coordinates Zoltan Turzo CFX 2 April 20, 2000 15:05
