porousSimpleFoam - crash
Old   January 4, 2012, 13:51
Default porousSimpleFoam - crash
Sebastian
Sebaj is on a distinguished road
Welcome Foamers
I spent all day on searching solutions for this error. I use porousSimpleFoam and I took mesh from Fluent. look's like a simple problem - the one input one output plus the porous zone. after 20 iterations the simulation breaks down..
I would ask for any suggestions what might be wrong where I made a mistake?
[plgsebaa@n1-4-4 wydob_1]$ porousSimpleFoam
| \\ / O peration | Version: 1.7.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 1.7.1-03e7e056c215
Exec : porousSimpleFoam
Date : Jan 04 2012
Time : 19:23:06
Host : n1-4-4.local
PID : 7370
Case : /mnt/auto/people/plgsebaa/test_case/wydob_1
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
sigmaEps 1.3;
Creating porous zone: POROUS_ZONE
Starting time loop
Time = 0.01
smoothSolver: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.068853, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0364543, No Iterations 9
time step continuity errors : sum local = 3.87347e-12, global = 3.30007e-15, cumulative = 3.30007e-15
smoothSolver: Solving for epsilon, Initial residual = 0.999623, Final residual = 1.86974e-14, No Iterations 2
smoothSolver: Solving for k, Initial residual = 1, Final residual = 4.7752e-11, No Iterations 2
ExecutionTime = 0.74 s ClockTime = 1 s
Time = 0.02
smoothSolver: Solving for Ux, Initial residual = 0.342943, Final residual = 0.0107729, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.638351, Final residual = 0.0246273, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.592757, Final residual = 0.0367471, No Iterations 2
GAMG: Solving for p, Initial residual = 0.121501, Final residual = 0.00582584, No Iterations 3
time step continuity errors : sum local = 2.19959e-09, global = 3.49719e-12, cumulative = 3.50049e-12
smoothSolver: Solving for epsilon, Initial residual = 0.99988, Final residual = 1.16313e-15, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.999905, Final residual = 2.64026e-09, No Iterations 2
ExecutionTime = 1.2 s ClockTime = 1 s
Time = 0.21
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 9.29518e-50, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 1.21793e-49, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 3.46985e-50, No Iterations 2
GAMG: Solving for p, Initial residual = 0.00823832, Final residual = 0.000275484, No Iterations 1
time step continuity errors : sum local = 5.75209e+56, global = -7.33984e+51, cumulative = -7.33984e+51
smoothSolver: Solving for epsilon, Initial residual = 0.00156525, Final residual = 87816.5, No Iterations 1000
bounding epsilon, min: 8.27141e-24 max: 1.32026e+116 average: 1.68431e+112
smoothSolver: Solving for k, Initial residual = 3.36682e-29, Final residual = 3.36682e-29, No Iterations 0
ExecutionTime = 18.27 s ClockTime = 19 s
Time = 0.22
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 7.10764e-85, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 6.8068e-85, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 2.53065e-85, No Iterations 2
#0 Foam::error:rintStack(Foam::Ostream&) in "/software/local/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/software/local/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/software/local/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/software/local/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/software/local/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/software/local/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/software/local/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libfiniteVolume.so"
#8 main in "/software/local/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/porousSimpleFoam"
#9 __libc_start_main in "/lib64/libc.so.6"
#10 _start in "/software/local/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/porousSimpleFoam"
Floating point exception
and files with msh
http://speedy.sh/pbF98/porousSimpleFoam.tar.gz
thanks for reply,
Sebaj
Sebaj is offline   Reply With Quote
Old   January 4, 2012, 13:58
Martin
MartinB will become famous soon enough
Hi Sebaj,
wrong dimensions I suppose. Use
transformPoints -scale "(0.001 0.001 0.001)"
and give it another try...
Good luck
Martin
MartinB is offline   Reply With Quote
Old   January 4, 2012, 16:16
Sebastian
thanks Martin!
It's works
poroussimplefoam
[ANSYS Meshing] ANSYS meshing crash when started robert86 ANSYS Meshing & Geometry 1 March 16, 2011 04:47
Dragging Slice File = Crash cbritan OpenFOAM Bugs 3 January 6, 2011 03:58
porousSimpleFoam bug in 1.7.x chibsen OpenFOAM Bugs 4 August 6, 2010 17:26
Graphic/plotted monitors causing Fluent 12.0 to crash Autumn FLUENT 6 May 25, 2010 01:19
Flow Simulation Crash with Trajectories D.Castle FloEFD, FloWorks & FloTHERM 2 August 5, 2009 14:50
