March 31, 2011, 05:24 |
Markus Rehm
have a look at timeVaryingMappedFixedValue a tutorial is in pitzDailyExptInlet Hope that helps, Markus. Edit: This applies for the boundary conditions. |
March 31, 2011, 05:51 |
Thanks Markus,
I want map all of domain fields value. the problem is: mapping is from wedge which is 2D to a 3D geometry. i have a rectangle for example and want rotate it in different angles to create a cylinder. in this condition all angles have a tangential radial and axial velocity same as initial 2D wedge. Any suggestion will be appreciated. |
[blockMesh] Problems in creating a wedge type mesh | Joscha | OpenFOAM Meshing & Mesh Conversion | 28 | August 3, 2019 07:59 |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 03:02 |
solid to fluid heattransfer with chtMultiRegionFoam | nakor | OpenFOAM | 11 | March 21, 2011 08:28 |
Wall boundary is ignored when using wedge | Wedge | OpenFOAM | 1 | February 7, 2011 06:20 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
