March 28, 2011, 03:19 |
OpenFoam to CFX
chyn wey lee
Rep Power: 17 |
Hi all
Is there a way to export data from OpenFoam to CFX post for post processing? |
March 28, 2011, 04:30 |
sirLentschi
Rep Power: 15 |
you can use foamToCGNS. Regards Markus |
March 31, 2011, 08:31 |
xuqy
Rep Power: 16 |
foamToCGNS is a standard utility in openfoam-1.7.1?
Why I can't find it? |
March 31, 2011, 08:55 |
Niels Nielsen
Rep Power: 27 |
foamToCGNS is part of the turbomachinery OSIG for 1.5-dev.
It will work for 1.6-ext with a little modification. The easiest way to get from OF to CFX without relying on thirdparty tools is using foamMeshToFluent (for the mesh only) CFX can import fluent mesh. (not polyhedra cells)
Linnemann PS. I do not do personal support, so please post in the forums. |
March 31, 2011, 11:24 |
chyn wey lee
Rep Power: 17 |
I have problem importing the foamdata to cfx. I am currently trying to benchmark openfoam and cfx using the same pre processor and post. trying to bench mark the solver. any one have tried importing foam data to cfx appreciate some help
April 5, 2011, 01:54 |
Kurne
Rep Power: 15 |
Dear chyn wey lee
I have successfully transfer the result data from the foam to CFX. The procedure is that first of all you have to use utility foamDataToFluent and this will convert the data in Fluent readable format.Then you can open the fluent and first import the mesh i.e fluent.msh format mesh and then import the file obtain by utility foamDataToFluent. In fluent there is an options to convert the fluent data to CFD Post with this you can transfer the data from the Fluent to CFX. If you find any difficulties then let me know. Cheers.....
Simulation Is Determination Of Imagination Towards Approximation ® Best Regards Mubeen K Kurne |
May 26, 2011, 09:30 |
José
Rep Power: 15 |
Dear Kurne,
Is there any way to make the conversion without going through Fluent? I do not have Fluent and this is the reason why I would rather convert the data straight from OpenFOAM to ANSYS CFX. Thanks! Regards, José |
September 27, 2011, 05:50 |
Rep Power: 17 |
HI Everybody,
I am also interested in a possibility to convert OpenFoam Results to CFX readable file for postprocessing! Is there a way? Jose have you found something? Camoesas |
September 28, 2011, 05:29 |
#9 |
Rep Power: 17 |
January 12, 2012, 08:23 |
foamToCGNS for OpenFOAM-1.6-ext
#10 |
Thomas Lloyd
Rep Power: 15 |
Hi all,
I have installed the CGNS converters on OF-1.5-dev successfully. Can someome please tell me the modifications to make to files before it can be installed for OF-1.6-ext? Thanks, Thomas |
February 5, 2012, 13:37 |
#11 | |
Aqua
Rep Power: 14 |
Aqua |
February 5, 2012, 13:41 |
#12 | |
Aqua
Rep Power: 14 |
Thomas, Did you find the way to modify CGNS so that it can work for 1.6-ext? I am using 1.6-ext, so would really appericate if you can help on this. Thank you so much! Aqua |
February 6, 2012, 00:55 |
#13 |
Masashi Ohbuchi
Rep Power: 16 |
I've build cgnsToFoam, foamToCGNS and related libraries(libcgns, libcgnsoo) from source code for 1.5-dev without modification. These utilities worked fine on my PC. |
February 6, 2012, 05:46 |
#14 | |
Aqua
Rep Power: 14 |
did you mean that you built foamToCGNS on your computer for your 1.6-ext? Sorry my English is not that fluent.. Aqua |
March 2, 2012, 06:02 |
#15 | |
Aqua
Rep Power: 14 |
I am using foamToCGNS, the mesh is created in OpenFoam by SnappyHexMesh, but when run foamToCGNS, error happens like : Wrong number of vertices in cell expected 4,5,6, or 8, found 0 From function foamToCGNS in file writeCGNS.H at line 219. Does CGNS deal with polyhedral cell created by snappyHexMesh? If not, is there some other way to convert OF mesh to CFX? Thank you so much! Aqua |
OpenFOAM vs. Fluent & CFX | marco | FLUENT | 16 | November 17, 2020 04:53 |
CFX CLL OpenFOAM | hellorishi | OpenFOAM Pre-Processing | 1 | May 5, 2011 06:43 |
Importing solutions in CFX. | Alphonso | CFX | 1 | August 1, 2008 14:01 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
OpenFOAM Training and Workshop | Hrvoje Jasak | Main CFD Forum | 0 | October 7, 2005 07:14 |
