a problem with temperature depending properties |
March 28, 2011, 01:03 |
Maryam Mousazadeh
Rep Power: 15 |
hello
I want to simulate a case with nanofluid. I extracted transport and thermal properties equation which are conclude tow fluid and nanoparticles properties (in first method that you said). but viscosity and conductivity are temperature dependent. I tried to use thermophysical models but I didn't find where put the equations .however this way may be wrong. I add energy equation to simpleFoam and want to modify this solver to my simulation. do you have any opinion to help me. kind regards |
PorousMedia Problem with Temperature Distribution | pawan | OpenFOAM Running, Solving & CFD | 2 | August 2, 2015 23:08 |
static temperature is higher than total temp. in buoyancy problem | amirbahador | FLUENT | 2 | October 24, 2010 07:21 |
rotationally periodic properties vs temperature | Sasha | FLUENT | 0 | April 7, 2008 13:13 |
the material parameters depending on temperature | Jason | CFX | 4 | December 22, 2006 19:54 |
Problem with transport properties depending on Temperature | galaad | OpenFOAM Running, Solving & CFD | 5 | December 6, 2005 12:51 |
