Using scalar fields
Like Tree1Likes
  • 1 Post By r08n
Old   March 30, 2011, 05:59
Default Using scalar fields
gefufna is on a distinguished road
Hi everybody!
I have a question. I'm working on a case in which I use only scalar fields such as mass and substance concentration, which change in time. Is it possible in OpenFOAM to work on this case in such a way that I don't have to generate meshes? And is it possible to sample data only in time?
Thanks!
gefufna is offline   Reply With Quote
Old   March 31, 2011, 06:31
Robertas N.
r08n is on a distinguished road
Originally Posted by gefufna View Post
Hi everybody!
Thanks!
Do you mean -- no spatial dependencies? You could make a very simple mesh, using blockMesh, with only one cell. If you have only time (temporal)
dependencies, is your system, by chance, described by a set of ODEs? If this is the case, maybe, some simple[r than OF] ODE solver is sufficient. Can you
describe in more detail?
gefufna likes this.
r08n is offline   Reply With Quote
Old   April 1, 2011, 12:05
Hello, and thanks for your reply.
Yes, there is no spacial dependencies, only temporal. I'm working in a team on project in biochemical engineering, a part of which is modeled in Berkeley Madonna, and it has only temporal dependencies. However, we decided to move to OF, because in later stages of project we'll have to deal with spatial dependencies too, and BM has no such capabilities. Now I wish to re-model this part in OF, so that at the end the whole project should be in OF. I have a couple of ODEs, and result parameters should be plotted as a function of time.
Best regards!
dieselFoam problem!! trying to introduce a new heat transfer model vivek070176 OpenFOAM Programming & Development 10 December 23, 2014 23:48
Schemes for strictly bounded scalar fields stawrogin OpenFOAM 1 July 19, 2010 17:16
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
How to create a vector field out of scalar fields anja OpenFOAM Pre-Processing 7 May 31, 2006 11:56
ability of fluent to predict scalar fields in reacting flows ? Mounir Main CFD Forum 1 January 21, 1999 10:08
