simpleSRFFoam error in OpenFOAM 1.5-dev
Old   March 21, 2011, 00:10
Default simpleSRFFoam error in OpenFOAM 1.5-dev
Kurne
kurne is on a distinguished road
Dear All
I have installed OpenFOAM 1.5-dev and i have given run under simpleSRFFoam solver but i am getting the strange error after running it.Will somebody help me in solving this error.The error is as follows
| \\ / O peration | Version: 1.5-dev |
| \\ / A nd | Revision: exported |
| \\/ M anipulation | Web: http://www.OpenFOAM.org |
Exec : simpleSRFFoam
Date : Mar 21 2011
Time : 10:23:54
Host : ubuntu
PID : 2887
Case : /home/sameer/Bl65340/OF1.5dev/2
nProcs : 1
Create time
Create mesh for time = 0
Reading field p
Attempt to cast type patch to type lduInterface
From function refCast<To>(From&)
in file /build/buildd/openfoam-dev-1.5-1726/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/typeInfo.H at line 106.
FOAM aborting
Aborted
I am facing such type of error first time.I am waiting for help.Thanks in Advance
Simulation Is Determination Of Imagination Towards Approximation ®
Best Regards
Mubeen K Kurne
kurne is offline   Reply With Quote
Old   March 21, 2011, 04:21
Wei Zhao
zhaowei is on a distinguished road
I have similiar experience before, and it is the problem of boundary condition. Check your boundary condition carefully.
zhaowei is offline   Reply With Quote
Old   March 21, 2011, 07:14
Kurne
Dear Wei Zhao
I have check my boundary conditions many times but still i am facing the same problem.Will you please elaborate the term "Checking the boundary conditions carefully".
Thanks In Advance.
Best Regards
Mubeen K Kurne
Old   March 21, 2011, 11:22
Wei Zhao
The boundary condition is not only in your "boundary" file. If you run checkMesh and the result is ok, then your boundary file is fine. I think you might need to check your initial condition in 0 folder, especially the p file. Have you run the tutorials for simpleSRFFoam? Is this solver compiled well?
Good luck!
Old   April 6, 2011, 01:44
Kurne
Dear Wei Zhao
Yes i have compile the solver and it is running in the tutorial case.I am also implementing the similar type of problem and i have run in the OpenFOAM 1.7.1 but the problem is only in OpenFOAM 1.5-Dev.
I am still facing the same problem after observing the my initial conditions file and the MESH is ok.
Can Anybody help.
Thanks in advance.
Best Regards
Mubeen K Kurne
Old   April 20, 2011, 07:00
Kurne
Dear Wei Zhao
I got the solution.Thanks a lot for the help.
Best Regards
Mubeen K Kurne
[OpenFOAM] ParaFoam instalation in OpenFoam 1.5 dev titio ParaView 2 July 24, 2010 23:24
OpenFOAM 1.5 dev LVDH OpenFOAM 98 May 5, 2010 17:01
[OpenFOAM] ParaView/ParaFoam in OpenFoam 1.5 dev titio ParaView 2 February 27, 2010 14:02
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 12:13
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 12:12
