May 1, 2011, 04:20 |
Run openFoam in Multithreads
Ashok
Rep Power: 15 |
I am running OpenFoam in my PC. , which have following specifications Operating System: Ubuntu 10.10 32 bit Processor: i5, 2 cores and 4 threads But whenever I am monitoring the openFoam processing, it shows it is only using single thread. I heard that there is a way to run openFoam simultaneously in all my cores. Please help me... Thank you in advance. |
May 1, 2011, 06:57 |
Make sure you run your solver with: mpirun -np 4 <solvername> -parallel Regards, Jose |
May 1, 2011, 15:30 |
Sequence of Parallel Implimenation
Ashok
Rep Power: 15 |
Thank you very much,
That worked perfectly.But I have some more doubts.. 1, What is the sequence for running a parallel implementation. I mean for blockMesh and decomposePar, which one I should run first ? 2, I have used a stop watch to compare the speed gain in parallel processing from the normal processing. My processors were running at full load in parallel processing, but the speed gain was negligible. Why is it happening ? Do you have any suggestions in it ? Waiting for your reply. |
May 2, 2011, 04:05 |
Junaid Ahmad Khan
Rep Power: 16 |
Can this Command works as it is on GPU base computers
Regards Junaid |
May 2, 2011, 04:07 |
Anton Kidess
Rep Power: 29 |
1. First mesh, then decompose.
2. There are lots of threads on the forum and the Internet in general on this topic, go have a look. In short, parallelization is no guarantee for speedup. Your problem has to be suitable for your parallel environment. |
May 2, 2011, 11:07 |
Thanks
Ashok
Rep Power: 15 |
Thanks,
Comments were helpful. Ashok |
multiple cpu cores, openfoam, ubuntu |
OpenFOAM 1.6.x - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 68 | April 22, 2013 11:03 |
[mesh manipulation] createPatch / cyclicGgi / OpenFoam 1.5-dev | OFU | OpenFOAM Meshing & Mesh Conversion | 0 | June 16, 2010 04:36 |
Getting OpenFOAM to coexist with an existing JAVA VM | nik777 | OpenFOAM Installation | 5 | February 22, 2007 07:21 |
Help I canbt run FoamX report Unable to contact name server error | cornerstone | OpenFOAM Installation | 0 | May 3, 2006 01:14 |
Run FOAM on a remote machine | luckyluke | OpenFOAM Installation | 1 | June 21, 2005 05:19 |
