Compiler problem?
Like Tree1Likes
  • 1 Post By nimasam
Old   May 27, 2011, 04:46
Default Compiler problem?
Tanay Deshpande
Tanay is on a distinguished road
Hello people,
I think I have a compiler problem when I'm running the tutorials cavity in pisoFoam (ras) and cavityClipped in icoFoam. For example when I use "$ mapFields ../cavity" command in the latter, I get-
--> FOAM FATAL ERROR:
Cannot find file "points" in directory "polyMesh" in times 0.5 down to constant
From function Time::findInstance(const fileName&, const word&, const IOobject::readOption)
in file db/Time/findInstance.C at line 175.
FOAM exiting
My versions of OpenFOAM and Paraview are 1.7.1 & 3.8.1 respectively. What should I do?
Tanay is offline   Reply With Quote
Old   May 27, 2011, 09:56
Nima Samkhaniani
nimasam is on a distinguished road
did you use the blockMesh command to create geometry?
AviSh likes this.
nimasam is offline   Reply With Quote
Old   May 27, 2011, 12:42
Tanay Deshpande
Thanks, yeah, I had. Apparently it hadn't worked due to some reason. I quit the terminal and repeated the "$blockMesh" command. Then, I encountered no glitches. So basically, if OpenFOAM has been installed properly, there shouldn't be any C++ compiler problems while running it, right?
P.S.- This post is quite silly now, I should probably remove it.
Old   May 28, 2011, 04:45
Nima Samkhaniani
Above error said that points has not been found so it mightbe not created yet! so probable mistake could be that you forget to use blockMesh command
besides if you in doubt that the openFOAM has been installed properly or not
go to bin directory and use
./foamInstallationTest
and check configuration
compiler
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
