Error message when using buoyantSimpleFoam
Old   June 6, 2011, 05:53
Default Error message when using buoyantSimpleFoam
almir is on a distinguished road
hi,
i have a big problem when i try to use the function buoyantSimpleFoam.
OpenFoam brings me always this error message:
almir@ubuntu:~/OpenFOAM/Netz/mittel$ buoyantSimpleFoam
| \\ / O peration | Version: 1.7.x |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 1.7.x-3776603e4c6c
Exec : buoyantSimpleFoam
Date : Jun 01 2011
Time : 18:31:04
Host : ubuntu
PID : 2165
Case : /home/almir/OpenFOAM/Netz/mittel
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading g
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/almir/OpenFOAM/Netz/mittel/constant/g at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 61.
FOAM exiting
I dont understand that, when i go into the constant-folder there is no file called "g".
In my case i have about 300 patches, maybe the high number of patches is the problem. I have unit some of the patches in the boundary conditions (in the 0-folder) with the function
boundaryField
"patch[1-358]+"
type fixedValue;
value uniform 303.75; // 30.6 degC
maybe this is the problem??
but i also have made a simple example with an easy geometry with only 9 patches and i get same error message.
can somebody help me?
greets
almir
almir is offline   Reply With Quote
Old   June 6, 2011, 09:47
Andreas_F
Andreas_F is on a distinguished road
The error message is telling you that the g file does not exist. Try putting it in the constant directory.
Andreas_F is offline   Reply With Quote
Old   June 7, 2011, 05:52
hi Andreas,
thank you! you have solved my problem.
Old   June 8, 2011, 07:02
hi,
now OpenFoam brings me a new ErrorMessage:
almir@ubuntu:~/OpenFOAM/zylinder$ buoyantSimpleFoam
Date : Jun 08 2011
Time : 12:34:57
Host : ubuntu
PID : 4727
Case : /home/almir/OpenFOAM/zylinder
nProcs : 1
Create time
Reading g
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting RAS turbulence model kOmegaSST
--> FOAM FATAL ERROR:
Invalid wall function specification
Patch type for patch patch1 must be wall
Current patch type is patch
From function kqRWallFunctionFvPatchField::checkType()
in file derivedFvPatchFields/wallFunctions/kqRWallFunctions/kqRWallFunction/kqRWallFunctionFvPatchField.C at line 47.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::compressible::RASModels::kqRWallFu nctionFvPatchField<double> >::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#3 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
#4 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricB oundaryField(Foam::fvBoundaryMesh const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
#5 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::dictionary const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
#6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
#7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
#8 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::compressible::autoCreateWallFunctionField<do uble, Foam::compressible::RASModels::kqRWallFunctionFvPa tchField<double> >(Foam::word const&, Foam::fvMesh const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#9 Foam::compressible::autoCreateK(Foam::word const&, Foam::fvMesh const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#10 Foam::compressible::RASModels::kOmegaSST::kOmegaSS T(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#11 Foam::compressible::RASModel::adddictionaryConstru ctorToTable<Foam::compressible::RASModels::kOmegaS ST>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#12 Foam::compressible::RASModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#13
#14 __libc_start_main in "/lib/libc.so.6"
#15
Abgebrochen
I think my problem is that i have used for meshing Netgen 4.9.13. this was working quite good, and also the export to OpenFoam Format. But in the constant-folder my boundary-file is looking like that:
9
patch1
type patch;
physicalType patch;
nFaces 126;
startFace 7486;
patch2
type patch;
physicalType patch;
nFaces 132;
startFace 7612;
and i wont to use the tutorial-files from buoyantCavity for my research, and i have edited them with the patches i have from Netgen. For example i have edited alphat-file like that:
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object alphat;
dimensions [1 -1 -1 0 0 0 0];
internalField uniform 0;
boundaryField
"patch[4-9]+"
type alphatWallFunction;
Prt 0.85;
value uniform 0;
"patch[1-3]+"
Prt 0.85;
value uniform 0;
So my question is how i have to edit the files in the 0-folder (alphat, epsilon, k, mut...)? Or do i have to edit the boundary-file?
greets
buoyantSimpleFoam velocity oszillation 1.6-ext preibie OpenFOAM Running, Solving & CFD 4 May 13, 2011 04:09
Running buoyantSimpleFoam with oodles data as initialisation samulu OpenFOAM 5 November 19, 2009 11:49
BuoyantSimpleFoam amitshah OpenFOAM Running, Solving & CFD 4 June 3, 2009 06:04
buoyantSimpleFoam Message error Khelian973 OpenFOAM Running, Solving & CFD 8 June 2, 2009 13:26
buoyantSimpleFoam error message Khelian973 OpenFOAM Running, Solving & CFD 4 April 16, 2009 04:45
