turbulent kenetic energy
Old   June 7, 2011, 10:59
Default turbulent kenetic energy
s-ammarlu is on a distinguished road
hi
i have a question : how can we show turbulent kenetic energy , with openfoam 10.4 ?
thanks
s-ammarlu is offline   Reply With Quote
Old   June 7, 2011, 11:53
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
For all turbulent simulations run with standard OpenFoam solvers, the turbulent KE field is written for every time directory. You have many options to visualize, do you mean how to see it in ParaFoam/ParaView?
mturcios777 is offline   Reply With Quote
Old   June 7, 2011, 14:32
Default turbulent KE
Hi macro
excuse me , i cant show turbulent KE in parafoam or in open foam , i want the code that i get KE diagram from open foam .
best regard
Old   June 7, 2011, 14:39
Marco A. Turcios
Have you gone through the tutorial for lid-driven cavity flow, found in the User's Guide? Its located in:
OpenFOAM/OpenFOAM-1.x/docs/Guides-usletter/UserGuide.pdf
The tutorial will show you how to visualize fields, and by using a little thought you can figure out how to show the KE field instead of pressure. Make sure you are running the solver with turbulent activated.
Old   June 7, 2011, 14:50
yes i am running with oodles solver , but i cant see any turbulent structure in it .
Old   June 7, 2011, 14:58
Marco A. Turcios
If you are running oodles then you won't get turbulent kinetic energy unless you post-process the results, since you are using an LES model.
I'm not as familiar with the LES solvers. I see in the pitzDaily tutorial included there is a k field defined in the 0 time directory. Is that only an initial condition or if k written out every time?
question about turbulent kinetic energy junker4236 Main CFD Forum 19 April 19, 2017 04:46
LES and total turbulent kinetic energy Boerge FLUENT 1 September 8, 2012 11:41
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Turbulent Kinetic Energy Olga FLUENT 2 October 11, 2002 15:05
calculation of (turbulent) dissipation energy ? max Main CFD Forum 3 August 18, 1999 09:42
