non-real values on output BC-whats the limit of output pressure?
Old   July 1, 2013, 16:42
Default non-real values on output BC-whats the limit of output pressure?
immortality's Avatar
Ehsan
immortality is on a distinguished road
whats incorrect in this case?
it seems there is a limit on output pressure that below that solution gives non correct solution on the outlet mainly on neighbors.
the tube is filled by a high pressure fluid(1800000 I used here) and opening has a lower pressure.it seems where this pressure on BC goes lower than a value it gives improper results(internalField values shouldn't be lower than the boundary)but I don't know whats this pressure limit.
has had anyone of CFD fans! such an experience or have knowledge about?(maybe a gasdynamic rule there is for it)
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Specifying the pressure values for the Fan characteristic curve saisanthoshm88 FLUENT 2 December 2, 2016 02:22
UDF error - FLUENT received fatal signal (ACCESS_VIOLATION) Eliasjal Fluent UDF and Scheme Programming 1 March 7, 2012 11:11
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
Total pressure in real gas (compressible flow) Bart Prast Main CFD Forum 3 November 14, 2000 10:44
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
