div(phi,U) in an incompressible solver
Old   June 8, 2011, 11:47
Question div(phi,U) in an incompressible solver
fisch
fisch is on a distinguished road
Hi Foamers,
does anybody know if div(phi,U) in an incompressible solver (like simpleFoam) is calculating the "full" divergence term of phi*U or is it directely introducing the incompressibility conditions that the calculation would be reduced to the half.
For a better understanding what i mean i will write it analytical for 2D motion (i will leave out the density):
Option a) div(U,U) = u*( du/dx+dv/dy) + u*du/dx + v*du/dy
Option b) div(U,U) = u*du/dx + v*du/dy (because the term in the brackets satisfies div(U)=0)
Which option is openFoam using?
Thanks a lot,
rupert
fisch is offline   Reply With Quote
Old   June 8, 2011, 13:44
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Rupert, FOAM solves the "weak" form if this term. When you use FVM, integrals are volumetric at the beginning but using the Gauss Theorem you don't have to use any derivatives but only values at faces, because you have a surface integral:
int_{Omega} div(U*U) dOmega=int_{Gamma} U*U&d_Gamma=sum_f U_f*U_f&S_f=sum_f U_f*phi_f
where & is the dot product, Omega is the control volume and Gamma is its border and f indicates quantities at faces. phi is the flux U_f&S_f.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   June 9, 2011, 07:21
Paulo Vatavuk
vatavuk is on a distinguished road
Hi Rupert,
Just complementing Santiago's answer, this means that, for the x momentum equation, you have alternative a) integrated over the cell volume.
Paulo
vatavuk is offline   Reply With Quote
Old   June 9, 2011, 07:46
fisch
Hi Paulo and Santiago,
thanks for the reply. Both answers are helping me.
So if i want to add to an equation one more term i have to integrate it over the cell volume or just multiply the cell center value with the Volume of the cell, right?
For example if i want to add a value S (like a source term) i have to integrate this value over the cell volume, too, right?
Thanks
rupert
Old   June 9, 2011, 07:51
Rupert, the integration is part of the method and is implied using FOAM. Adding S to the equation starts a chain of events that finally integrate the source over each cell. The other option is to use the fvm::Sp().
Regards.
Research Scientist
Old   June 9, 2011, 09:34
fisch
Hello Santiago,
does that mean that the integration is implied in the discretization schemes (like in e.g. div(phi,U)) or is it automatically implied while solving an equation???
The difference would be that i don't have to integrate my source term my own if it is done by the solve() procedure...
Can you understand what i mean??
As far as i get it out of the source code the Sp() function is anyhow multiplying with the cell Volumes; but i had no success to use it right :-/ ...
Further: what is wrong if i type: volScalarField meshVols = U.mesh().V();
There is a compiler error: error: conversion from ‘const Foam:imensionedField<double, Foam::volMesh>’ to non-scalar type ‘Foam::volScalarField’ requested
Maybe you have some answers.
thanks a lot,
rupert
Old   June 10, 2011, 11:32
Sabin Ceuca
sabin.ceuca is on a distinguished road
thanks a lot,
rupert
Hi Rupert,
I can help you on this one :
tmp<volScalarField> cellVolume
new volScalarField
IOobject
"cellVolume",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
mesh,
dimensionedScalar("zero",dimensionSet
(0, 3, 0, 0, 0, 0, 0), 0.0)
cellVolume().internalField() = mesh.V();
This part should store the volumes of your cells. I don't really understand why you call your volume like U.mesh().V ?
Regards,
sabin
sabin.ceuca is offline   Reply With Quote
Old   June 14, 2011, 01:42
fisch
Regards.
Santiago,
do i have to use some integration over the cell volume inside an equation for the additional source term S or is it done automatically so that i have to add only the term with " + S" or do i need something else??
Thanks for your help.
rupert
Old   June 25, 2013, 12:16
Anne Gerdes
Anne Lincke is on a distinguished road
Good evening,
I have the same question.
I have added an explicit source term rhs in the momentum equation
HTML Code:
tmp<fvVectorMatrix> UEqn
            fvm::div(phi, U)
            + turbulence->divDevReff(U)
              +rhs
Is this source term automatically multiplied by the control volumes = integrated?
In my case I would like to add a face-based source term which includes the face magnitudes. Therefore I suppose that I need to divide my source term by the control volume, as I do not want it to be multiplied as the multiplication with the face magnitude symbols an integration over the face already.
Can someone please verify that the source term is automatically integrated if I insert it in the UEqn like stated above?
I am looking forward to your answers.
Kind Regards
Anne
Anne Lincke is offline   Reply With Quote
Old   June 25, 2013, 18:51
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You can use the cell center value not the cell integrated value when you specify
the explicit source term in the UEqn.
Hope that helps,
Fumiya
fumiya is offline   Reply With Quote
Old   June 26, 2013, 02:56
Anne Gerdes
Dear Fumiya,
thank you very much for your answer.
How can I switch between cell-centered and cell-integrated value?
Thank you,
Anne Lincke
Old   June 27, 2013, 14:06
Anne Gerdes
Dear foamers,
I have written a face-based source which I would like to include in the UEqn.
I assume that this term will automatically multiplied with the cell-volume as it is explicit?
As the term corresponds to the integration over the faces it is already scaled with the face-magnitude and does not need to be scaled by the cell volume any more.
Therefore I divided the term by the cell volume, but the code does not converge
In the following a sketch of the code.
HTML Code:
for( label faceI=0; faceI < mesh.nInternalFaces(); faceI++)
    label P = owner[faceI];
    label N = neighbour[faceI];
    rhs[P] = rhs[P] + mesh.Sf()[faceI]*Uf[faceI]*1/mesh.V()[P];
Can I somehow avoid the automatic scalation with the cell center volume inside the UEqn?
Thank you very much for an answer.
Anne
Old   June 28, 2013, 08:40
Eysteinn Helgason
eysteinn is on a distinguished road
Originally Posted by Anne Lincke View Post
Dear foamers,
Anne
Hi Anne,
Yes it is automatically multiplied with the cell volume.
I think you might be looking for the reconstruct operator to get the value in
the cell center:
surfaceScalarField phi
         = fvc::interpolate(U) & mesh.Sf();
volVectorField UfromPhi("UfromPhi",fvc::reconstruct(phi) );
/Eysteinn
eysteinn is offline   Reply With Quote
Old   July 1, 2013, 10:40
Anne Gerdes
Thank you, I think I found another reason for the non-convergence of my code.
Nevertheless this implementation helped me a lot to understand how OpenFOAM treats the source terms.
Kind Regards
Anne
LES solver with variable density for incompressible liquids matthias OpenFOAM Running, Solving & CFD 1 April 26, 2010 05:46
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM 0 April 4, 2010 18:06
An FASMultigrid solver for steady incompressible viscous flow luca_g OpenFOAM Running, Solving & CFD 3 September 21, 2009 02:30
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
Incompressible flow solver (staggered grid) J. Ehrhard Main CFD Forum 1 October 8, 1998 19:47
