August 2, 2011, 13:18 |
problem with restarting the jobs
huxiaoxia
I run some cases with interFoam. But when the running time is up, if I want to continue running the cases, it shows the problem " Build : 1.7.1-03e7e056c215 Exec : interFoam -parallel -case . Date : Aug 02 2011 Time : 12:49:54 Host : cs295 PID : 12347 Case : /netmount/ip11_home/huxiaoxi/OpenFOAM/huxiaoxia/spatial70con nProcs : 4 Slaves : 3 ( cs295.12348 cs295.12349 cs295.12350 ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0.00428 Reading field p_rgh Reading field alpha1 Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type LESModel Selecting LES turbulence model oneEqEddy oneEqEddyCoeffs { ce 1.048; ck 0.094; } Reading g Calculating field g.h time step continuity errors : sum local = 2.858218e-11, global = 1.700856e-15, cumulative = 1.700856e-15 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 1.880548e-06, No Iterations 3 GAMGPCG: Solving for pcorr, Initial residual = 9.402672e-07, Final residual = 9.402672e-07, No Iterations 0 time step continuity errors : sum local = 5.37502e-17, global = -6.884058e-20, cumulative = 1.700787e-15 Courant Number mean: 0.0001182975 max: 0.0007596963 Starting time loop Courant Number mean: 0.0001182975 max: 0.0007596963 Interface Courant Number mean: 4.086113e-07 max: 0.0004351158 deltaT = 1.199976e-09 Time = 0.004280001 --> FOAM Warning : From function Time:perator++() in file db/Time/Time.C at line 681 Increased the timePrecision from 7 to 8 to distinguish between timeNames at time 0.00428 MULES: Solving for alpha1 Liquid phase volume fraction = 0.04687154 Min(alpha1) = -1100.25 Max(alpha1) = 1295.916 MULES: Solving for alpha1 Liquid phase volume fraction = 0.04687156 Min(alpha1) = -1099.25 Max(alpha1) = 1294.916 MULES: Solving for alpha1 Liquid phase volume fraction = 0.04687157 Min(alpha1) = -1098.25 Max(alpha1) = 1293.916 MULES: Solving for alpha1 Liquid phase volume fraction = 0.04687158 Min(alpha1) = -1097.249 Max(alpha1) = 1292.916 " Can anyone help me ? Thanks. |
August 3, 2011, 03:51 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings huxiaoxia,
This is pretty simple - the error message reads: Quote:
The time resolution is very small, so if you want to save these small time steps, you'll need to increase the number of digits saved in the folder name! Best regards, Bruno
August 3, 2011, 11:14 |
huxiaoxia
Thanks a lot.
August 4, 2011, 05:05 |
Sabin Ceuca
Hi huxiaoxia,
you should consider this "warning" only if you think you could have numerical problems due to small time steps. In any other case OF takes care of this, as you can see in the message Time = 0.004280001 --> FOAM Warning : From function Timeerator++() in file db/Time/Time.C at line 681 Increased the timePrecision from 7 to 8 to distinguish between timeNames at time 0.00428 It will still save the times you have chosen in controlDict. Regards, sabin |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 07:27 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
