How to use "interpolation" utility in my own code
Old   August 11, 2011, 14:57
Default How to use "interpolation" utility in my own code
Frank Yu
frankyux is on a distinguished road
I am trying to call the interpolation functions from "finiteVolume" folder in my own code. My purpose is, by knowing a GeometricField ( "vf" for example ) and it's corresponding mesh grid ( mesh().C(), a volVectorField? ), given a coordinate (x0,y0,z0), interpolate the function value vf(x0,y0,z0).
I've read through the source code in " .../finiteVolume/interpolation/... " and " .../OpenFOAM/interpolations/... ", didn't find any function can fit my input format, which is a GeometricField, volVectorField, and a vector (x,y,z). Any similar situation have you been through before? Or any ideas?
Thanks for your time.
Frank
frankyux is offline   Reply With Quote
Old   September 7, 2011, 12:28
Frank Yu
Have tried some alternative ways but still doesn't work, anybody knows how to solve it? or any similar situations?
Old   September 7, 2011, 13:57
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hi Frank,
what do you inted to do? Do you want to interpolate around a point?
Or do you want the value in a specific point?
For interpolation to the mesh faces just go
surfaceVectorField sVF = vF.interpolate();
Then search for the face center closest to what you need. Grap its face id and do
vector sV = sVF[faceI];
You definitely need to specify because interpolation is a very wide field...
Then we can try to help you!
Best
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   September 7, 2011, 14:06
Frank Yu
Hi Kathrin,
Thanks for the reply. My purpose is, given a specific point 'vector X', find out what is the value of vf.oldTime() at that point. And since that point 'X' may not exactly on the meshgrid, i need to interpolate it by the known vf values.
Frank
Old   September 8, 2011, 02:26
Kathrin Kissling
Hi Frank,
so what you need to do:
First find the cell where it is located:
label myCellLabel = mesh.findNearestCell(yourPoint);
labelList adjacentCells = mesh.cellCells()[myCellLabel];
Then find the centers of the adjacent cells calculte the distance to your point -> weighting factors and interpolate
Hope this being of help!
Kathrin
Old   September 9, 2011, 11:57
Frank Yu
Thanks a lot Kathrin, this is very helpful.
I assume the default search method is 'octree' used in
label myCellLabel = mesh().findNearestCell(yourPoint);
it seems time consuming when doing the search. I also tried other method such as
label myCellLabel = mesh().findNearestCellLinear(yourPoint);
label myCellLabel = mesh().findNearestCellWalk(yourPoint, patchI);
where 'patchI' is my reference index. When I make the file, is says
finiteVolume/ddtSchemes/EulerDdtScheme/EulerDdtScheme.C: In member function ‘Foam::tmp<Foam::fvMatrix<Type> > Foam::fv::EulerDdtScheme<Type>::fvmDdt(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::Tensor<double>]’:
finiteVolume/ddtSchemes/EulerDdtScheme/EulerDdtSchemes.C:37: instantiated from here
finiteVolume/ddtSchemes/EulerDdtScheme/EulerDdtScheme.C:520: error: ‘const class Foam::fvMesh’ has no member named ‘findNearestCellWalk’
Doesn't all search utilities come from the following directory, or I missed something again?
/home/frank/OpenFOAM/OpenFOAM-2.0.0/src/meshTools/meshSearch/meshSearch.C
Old   September 10, 2011, 19:39
Frank Yu
Problem solved, should use following commends:
meshSearch ms(mesh());
label myCellLabel = ms.findNearestCell(X,patchI);
with a reference seedcell patchI, the search is much faster than before. (given a large number of cells).
Again, many thanks Kathrin!
-Frank
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 12:30
How to make code run in parallel? cwang5 OpenFOAM Programming & Development 1 May 30, 2011 04:47
Open Source Vs Commercial Software MechE OpenFOAM 28 May 16, 2011 11:02
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 10:11
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
