August 24, 2011, 04:33 |
converting ICEM grid to OpenFOAM fails
Rep Power: 15 |
Dear folks,
I have the following problem using ICEM as a mesher. I am meshed up a bearing chamber with several different faces and two different bodies which are representing different volumes with different media (air, oil). The problem is this error-message coming out when trying to convert (fluentMeshToFoam XXX.msh) the net into OpenFOAM. I donīt know what to do or what is wrong - where lies the problem to solve?? This is the error-message: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Dimension of grid: 3 Number of points: 86400 Reading points Number of cells: 80736 Other readCellGroupData: c 1 13b60 1 4 Reading uniform cells number of faces: 244992 Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Read zone1:12 name:BODY patchTypeID:fluid Reading zone data Read zone1:13 name:int_BODY patchTypeID:interior Reading zone data Read zone1:14 name:WALLFRONT patchTypeID:wall Reading zone data Read zone1:15 name:WALLOUTER patchTypeID:wall Reading zone data Read zone1:16 name:WALLINNER patchTypeID:wall Reading zone data FINISHED LEXING dimension of grid: 3 Creating shapes for 3-D cells --> FOAM FATAL ERROR: Cannot find match for face 5. Model: hex model face: 4(1 2 6 5) Mesh faces: 6 ( 4(6 7 3 2) 4(3 7 5 1) 4(4 6 2 0) 4(5 7 6 4) 4(2 3 1 0) 4(6 7 3 2) ) Matched points: 8(6 4 0 2 7 5 1 3) From function create3DCellShape(const label cellIndex, const labelList& faceLabels, const labelListList& faces, const labelList& owner, const labelList& neighbour, const label fluentCellModelID) in file create3DCellShape.C at line 281. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/home/itsnas/michael/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/itsnas/michael/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::create3DCellShape(int, Foam::List<int> const&, Foam::List<Foam::face> const&, Foam::List<int> const&, Foam::List<int> const&, int) in "/home/itsnas/michael/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/fluentMeshToFoam" #3 main in "/home/itsnas/michael/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/fluentMeshToFoam" #4 __libc_start_main in "/lib64/libc.so.6" #5 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 Abort Exit 134 Can anybody help me where to begin with this error?? Thanks a lot in advance!! Cheers, Mike |
August 24, 2011, 07:39 |
Rep Power: 16 |
Try using fluent3DMeshToFoam , and the mesh must be saved/exported in the ascii mode, not binary. |
August 25, 2011, 06:22 |
Rep Power: 15 |
Ok now converting/transferring into OF went fine..!
But here another error which came out while trying to run interFoam: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6.x-8ff188cd556c Exec : interFoam Date : Aug 25 2011 Time : 12:06:09 Host : itsnc1 PID : 32184 Case : /home/itsnas/michael/OpenFOAM/michael-1.6.x/run/Tests/Running/test/TestNewest2 nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading field p Reading field alpha1 Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar time step continuity errors : sum local = 4.96605e-17, global = 4.4311e-18, cumulative = 4.4311e-18 --> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 1e-300 Specified mass inflow : 3.84968e-17 Specified mass outflow : 4.60399e-17 Adjustable mass outflow : 0 From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p in file cfdTools/general/adjustPhi/adjustPhi.C at line 116. FOAM exiting Exit 1 Hope anybody can make something out of this..!! Where can I solve the problem - The thing is: I donīt have an in-/outlet yet, they are meant to be additions later.. Thanks a lot in advance! Cheers, Mike |
converting error, icem cfd, openfoam |
[Commercial meshers] Pointwise grid export to Openfoam | Eren10 | OpenFOAM Meshing & Mesh Conversion | 15 | May 30, 2019 17:10 |
[ICEM] Exporting Grid Volumes/Areas from ICEM to Calculate Discretization Error | Josh | ANSYS Meshing & Geometry | 4 | May 20, 2010 13:40 |
How to generate 2D grid of CFL3D in ICEM? | aladdincham | Main CFD Forum | 0 | March 11, 2010 02:19 |
[Gmsh] Error converting Gmsh mesh to OpenFOAM format | Martin_ | OpenFOAM Meshing & Mesh Conversion | 3 | December 9, 2009 09:35 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
