September 29, 2011, 05:07 |
Different FOAM executables
Madeleine P. Vincent
Rep Power: 15 |
Hi all,
I was wondering if there is a comprehensive list of all the FOAM executables out there. I can see all of the applications in the applications/bin directory. But I'm looking for a description, as well. Specifically I'm interested in fluid flow modeling. So this is my understanding: simpleFoam - for steady flow, both incompressible and compressible pisoFoam - for unsteady flow, both incompressible and compressible icoFoam - steady and unsteady incompressible flow Can all of the above also model turbulence? And what other possibilities are there? Thanks for your help, Madeleine. |
September 29, 2011, 05:35 |
Philip Cardiff
Rep Power: 34 |
The OpenCFD OpenFOAM site gives a brief description of all the solver. http://www.openfoam.com/features/standard-solvers.php There are also additional solvers in the OpenFOAM Extend branch (http://www.extend-project.de/). If you browse through the $FOAM_SOLVERS directory you can see all the solvers and a brief description is given in the main solver file. Philip |
September 30, 2011, 05:14 |
Rep Power: 15 |
Philip,
thanks. That's exactly what I was looking for. M. |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
