autoPatch error, mesh quality related...?
Old   October 6, 2011, 17:57
Default autoPatch error, mesh quality related...?
Alex
Alexvader is on a distinguished road
Hi
I have made a mesh with gmsh,
gmshToFoam reports this :
|  \\    /   O peration     | Version:  1.5-dev                               |
|   \\  /    A nd           | Revision: 1861                                  |
|    \\/     M anipulation  | Web:      http://www.OpenFOAM.org               |
Exec   : gmshToFoam test.msh
Date   : Oct 06 2011
Time   : 22:53:35
Host   : iskandhar
PID    : 20516
Case   : /home/alex/OpenFOAM/alex-1.5-dev/run/icoLagrangianFoam/GSNewTest
nProcs : 1
Create time
Found $MeshFormat tag; assuming version 2 file format.
Starting to read points at line 5
Vertices to be read:82487
Vertices read:82487
Starting to read cells at line 82495
Cells to be read:470722
Unhandled element 15 at line 82497
Unhandled element 15 at line 82498
Unhandled element 15 at line 82499
Unhandled element 15 at line 82500
Unhandled element 15 at line 82501
Unhandled element 15 at line 82502
Unhandled element 15 at line 82503
Unhandled element 15 at line 82504
Unhandled element 15 at line 82505
Unhandled element 15 at line 82506
Unhandled element 15 at line 82507
Unhandled element 15 at line 82508
Unhandled element 15 at line 82509
Unhandled element 15 at line 82510
Unhandled element 15 at line 82511
Unhandled element 15 at line 82512
Unhandled element 15 at line 82513
Unhandled element 15 at line 82514
Unhandled element 15 at line 82515
Unhandled element 15 at line 82516
Unhandled element 15 at line 82517
Unhandled element 15 at line 82518
Unhandled element 1 at line 83347
Unhandled element 1 at line 83348
Unhandled element 1 at line 83349
Unhandled element 1 at line 83350
Unhandled element 1 at line 83351
Unhandled element 1 at line 83352
Mapping region 0 to Foam patch 0
Mapping region 0 to Foam cellZone 0
Cells:
    total:427626
    hex  :0
    prism:0
    pyr  :0
    tet  :427626
CellZones:
Zone    Size
    0   427626
Skipping tag  at line 553220
Patch 0 gets name patch0
--> FOAM Warning :
    From function polyMesh::polyMesh(... construct from shapes...)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 582
    Found 42240 undefined faces in mesh; adding to default patch.
Finding faces of patch 0
FaceZones:
Zone    Size
Writing zone 0 to cellZone cellZone_0 and cellSet
End
the checkMesh report is as follows :
alex@iskandhar:~/OpenFOAM/alex-1.5-dev/run/icoLagrangianFoam/GSNewTest$ checkMesh
Exec   : checkMesh
Date   : Oct 06 2011
Time   : 22:46:33
Host   : iskandhar
PID    : 19949
nProcs : 1
Create time
Create polyMesh for time = constant
Time = constant
Mesh stats
    faces:            876372
    internal faces:   834132
    cells:            427626
    boundary patches: 2
    point zones:      0
    face zones:       0
    cell zones:       1
Number of cells of each type:
    hexahedra:     0
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    427626
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    patch0              42240    21122    ok (closed singly connected)
    defaultFaces        0        0        ok (empty)
Checking geometry...
    This is a 3-D mesh
    Overall domain bounding box (-0.05 -0.05 -0.05) (0.33 0.08 0.05)
    Mesh (non-empty) directions (1 1 1)
    Mesh (non-empty, non-wedge) dimensions 3
 ***Boundary openness (-1.57384e-17 -8.99149e-06 -5.84373e-05) Threshold = 1e-06 possible hole in boundary description.
 ***Open cells found, max cell openness: 1, number of open cells 10 Threshold = 1e-06
  <<Writing 10 non closed cells to set nonClosedCells
  <<Writing 2 cells with high aspect ratio to set highAspectRatioCells
    Minumum face area = 6.1923e-08. Maximum face area = 2.40286e-05.  Face area magnitudes OK.
    Min volume = 6.78547e-25. Max volume = 2.93558e-08.  Total volume = 0.0024085.  Cell volumes OK.
    Mesh non-orthogonality Max: 154.128 average: 23.0245 Threshold = 70
   *Number of severely non-orthogonal faces: 4.
 ***Number of non-orthogonality errors: 10.
  <<Writing 14 non-orthogonal faces to set nonOrthoFaces
 ***Error in face pyramids: 16 faces are incorrectly oriented.
  <<Writing 14 faces with incorrect orientation to set wrongOrientedFaces
 ***Max skewness = 213.4, 4 highly skew faces detected which may impair the quality of the results Threshold = 4
  <<Writing 4 skew faces to set skewFaces
Failed 5 mesh checks.
End
the autoPatch reports this, failing :
alex@iskandhar:~/OpenFOAM/alex-1.5-dev/run/icoLagrangianFoam/GSNewTest$ autoPatch 14
Exec   : autoPatch 14
Date   : Oct 06 2011
Time   : 22:51:21
Host   : iskandhar
PID    : 20359
nProcs : 1
Create time
Create polyMesh for time = 0
Mesh read in = 1.59 s
Feature:14
minCos :0.970296
Assigned 32400 faces to patch auto0
Assigned 28 faces to patch auto1
Assigned 287 faces to patch auto2
Assigned 112 faces to patch auto3
Assigned 1168 faces to patch auto4
Assigned 768 faces to patch auto5
Assigned 2632 faces to patch auto6
Assigned 287 faces to patch auto7
Assigned 28 faces to patch auto8
Assigned 288 faces to patch auto9
Assigned 287 faces to patch auto10
Assigned 2664 faces to patch auto11
Assigned 287 faces to patch auto12
Assigned 104 faces to patch auto13
Assigned 104 faces to patch auto14
Assigned 112 faces to patch auto15
Assigned 28 faces to patch auto16
Assigned 288 faces to patch auto17
Assigned 28 faces to patch auto18
Assigned 1 faces to patch auto19
Assigned 28 faces to patch auto20
Assigned 28 faces to patch auto21
Assigned 28 faces to patch auto22
Assigned 28 faces to patch auto23
Assigned 28 faces to patch auto24
Assigned 28 faces to patch auto25
Assigned 28 faces to patch auto26
Assigned 112 faces to patch auto27
Assigned 1 faces to patch auto28
Assigned 28 faces to patch auto29
Assigned 1 faces to patch auto30
Assigned 1 faces to patch auto31
--> FOAM Warning :
    From function SolverInfo::SolverInfo(const dictionary& dict,const objectRegistry &obr)
    in file SolverInfo/SolverInfo.C at line 61
    Can't find phi-field with name phi
Assumin incompressible solver
Attempt to cast type polyMesh to type fvMesh
    From function refCast<To>(From&)
    in file /home/alex/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/typeInfo.H at line 106.
FOAM aborting
Aborted
Are these errors related...?
Are there any tools in OF allowing me to heal this mesh...?
BTW what is the best OSS mesher to OF, is it gmsh or Netgen...?
My mesh was built out of a *step file created by a commercial cad package...
BRGDS
Alex
Alexvader is offline   Reply With Quote
Improve Mesh quality - airfoil simulation Lukas84 STAR-CCM+ 4 July 6, 2010 10:07
early stall, poor convergence, and mesh quality everest CFX 2 May 12, 2010 16:27
[ICEM] Hex refinement negative quality afterwards Anorky ANSYS Meshing & Geometry 8 March 22, 2010 03:25
Different types of Mesh quality hagupta CFX 1 June 30, 2006 07:42
Gambit Mesh quality TOM FLUENT 1 February 8, 2002 07:00
