fluentmeshtofoam problem
Old   February 10, 2012, 03:10
Unhappy fluentmeshtofoam problem
niaz's Avatar
A_R
niaz is on a distinguished road
Hi Foamers
I want to simulate a circular cylinder. I used gambit for making mesh.
and I converted it without any problem. but during the solve, I get unusual value for Cd and Cl. I checked Aref and it is correct but I do not know what the problem is ?
plz help me
niaz is offline   Reply With Quote
Old   February 10, 2012, 04:15
Nima Samkhaniani
nimasam is on a distinguished road
Hi dear Amir
two points:
1) after you import your mesh, use the command "check mesh" and look the result, is it fine?
2) u may use non hexahedral mesh, so maybe you need to use different schemes in your fvSchemes, so try different schemes in ur fvSchemes
3) for non-orthogonal you can increase the correct number in fvSolution
maybe it helps
nimasam is offline   Reply With Quote
Old   February 10, 2012, 06:54
niaz's Avatar
A_R
Dear nima
I have applied your suggestion but I don`t get sutiable answer
and it has still irregular Cd and Cl please check my test case (click on it) if you can?
tnx
Old   February 10, 2012, 13:59
Nima Samkhaniani
Originally Posted by niaz View Post
Dear nima
tnx
hi i look at your case.
first: it seems everything is fine, did you check whether your simulation is converging or not?
second: Are you sure the calculation of Cd is right?
if answer to both aforementioned questions are yes
then i suggest first turn of the turbulence and check whether it returns reasonable result for laminar case or not
Old   February 11, 2012, 02:36
niaz's Avatar
A_R
Hi Nima
my case is laminar not turb.
tanx it seems that the value of residuals cannot control the loops. and after 1 iteration the pimple loop for Uy exited. I have changed my loop corrector in Fvsolution and it seems more normal value.
Old   February 11, 2012, 03:10
Nima Samkhaniani
Hi
your simulation may be done in low velocity and it may be fall in low Reynolds number, and it is a laminar case! but i asked you to change the turbulence in the constant folder into laminar to omit all turbulence calculation in your case!
However im glad you reach a reasonable result
Old   February 11, 2012, 03:57
niaz's Avatar
A_R
Dear Nima
I had set laminar at first. the files are for next steps.
but it is running and it still looks good
tnx
fluentmeshtofoam, openfoam
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
