Fixed Flow rate and outlet Continuity Problem
Old   March 9, 2012, 14:18
Default Fixed Flow rate and outlet Continuity Problem
Mohammad.R.Shetab
mrshb4 is on a distinguished road
Dear Foamers,
I'm modeling a centrifugal fan in a fix flow rate with OF, but I had a problem and haven't find any solution for it!!!!
As I know in fluent it is modeled by these BCs:
inlet: massFlowRate
outlet: outflow
in OF I've tested many things like:
inlet: U: fixedFlowRate
p: fixedFluxPressure/zeroGradient
outlet: U: zeroGradient/fluxCorrectedVelocity
p: zerGradient
and a pRefCell and pRefValue for pressure reference. I think these Bcs are equivalent as the Fluent Bcs. When I run the MRFSimpleFoam the error would be
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 56.788705
Specified mass inflow : 0.55
Specified mass outflow : 0
Adjustable mass outflow : 0
What is the problem? Thanks for your help.!!!
mrshb4 is offline   Reply With Quote
Old   March 10, 2012, 14:32
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
when you use a fixedflowrate type for bcs.. you cannot constraint the outlet else you'll get this error...enforcing zerograd on U does it..try using inletout types with massflow types.. cuz then u can have backflow
or convert your massflow to velocity and use, if possible :
inlet
u=fixedvalue
p=zerograd
outlet
u=zerograd
p=fixedvalue
see if it works
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Problems in pressure when using mass flow rate outlet rafiktharwat CFX 11 January 2, 2014 17:21
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 02:42
How Other Conditions Impact Mass Flow Rate Outlet andy P. Main CFD Forum 2 February 9, 2007 10:41
Inlet and outlet flow rate Neser CFX 1 March 2, 2004 16:02
