problem with constant wall heat flux
Like Tree5Likes
  • 5 Post By openfoam1
Old   February 4, 2010, 07:46
Default problem with constant wall heat flux
openfoam1 is on a distinguished road
hi foamers
i want to use a fixed heat flux boundary condition in a conjugate heat transfer problem i use fixedGradient boundary condition on T ;
bottom
type fixedGradient;
gradient uniform 10.417;
i know that
heatflux = thermal conductivity (k) * tempreature gradient (dT/dN)
so for k=12 , heatflux=125 w/m2 >> gradient=heatflux/k=10.417
please help me ,, is that right to describe my constant heat flux (125 w/m2) in OpenFOAM ..
thank you very much ..
openfoam1 is offline   Reply With Quote
Old   February 4, 2010, 09:46
Stefan Herbert
herbert is on a distinguished road
this is the right way. Go on like this.
Regards
Stefan
herbert is offline   Reply With Quote
Old   June 23, 2014, 14:23
Ian Dizon
superian is on a distinguished road
hello, i am trying to set up something similar where i have a constant heat flux.
in my case i have lamps heating up air in a room.
my question is: would k be a property of the air? or of the lamp
superian is offline   Reply With Quote
Old   June 24, 2014, 03:07
Bárbara Arizmendi
Barbara is on a distinguished road
It depends on where you are fixing the heat flux. If you have simulated the lamp then you use the conductivity of the lamp. If you haven't simulated the lamp then you have to calculate the convective heat transfer coefficient (hc) or you can fix a HeatFlux boundary condition.
Barbara is offline   Reply With Quote
Old   July 16, 2014, 08:30
Default multiregion solid conduction
Anastasios
ageorg is on a distinguished road
Hi
I am also trying to do something similar and the option to fix the Gradient of T works fine but only if you have solids with the same k (thermal conductivity). If there are different domains with different k's the results are not as expected comparing with COMSOL or FLUENT applying the actual heat flux boundary value.
Has anyone dealt with something like this in ChtMultiRegionFoam if yes any advice would be really helpful!!!
Thanks in advance
T.
ageorg is offline   Reply With Quote
Old   August 15, 2016, 16:20
Default heat flux setting
alaa
alaa88 is on a distinguished road
Hi
I have case that their is constant heat flux from ground and i put it 500 w/m2
but their is a problem that it is not effect the density of the air or it's velocity
during solving and after calculation
please help
alaa88 is offline   Reply With Quote
Old   January 13, 2019, 08:18
Jianrui Zeng
calf.Z is on a distinguished road
If I use fixedGradient BC for constant heat flux, should thermo conductivity be constant? if it is changing with T, how should I get constant heat flux? Thank you.
calf.Z is offline   Reply With Quote
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 16:25
Constant heat flux with uniform temperature Jake Lee FLUENT 2 April 13, 2011 22:08
Heat flux and k-e wall boundary conditions Blob CFX 4 June 8, 2009 05:10
wall heat flux Sangeeta FLUENT 0 May 7, 2009 02:22
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
