[General] Normalizing data
Like Tree8Likes
  • 1 Post By flotus1
  • 5 Post By wyldckat
  • 1 Post By flotus1
  • 1 Post By vidyadhar
Old   August 5, 2013, 04:49
Unhappy Normalizing data
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
This question is so basic that I almost dont dare to ask.
How can I produce "normalized" variables directly in ParaView?
Say I have a scalar field "Velocity_X" on a Multi-block Dataset and I want to divide it by its maximum or average value.
The intuitive way with a calculator expression Velocity_X/max(Velocity_X) does not work/results in an error.
ERROR: In /home/utkarsh/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/Common/Misc/vtkFunctionParser.cxx, line 1484
vtkFunctionParser (0x4acef00): Syntax Error: two parameters separated by commas expected; see position 26
Warning: In /home/utkarsh/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/Filters/Core/vtkArrayCalculator.cxx, line 401
vtkPVArrayCalculator (0x4ecc410): An error occurred when parsing the calculator's function. See previous errors.
Edit:
Versions I tried are 3.14 and 3.98
aylalisa likes this.
flotus1 is offline   Reply With Quote
Old   August 6, 2013, 09:30
flotus1's Avatar
Alex
Any Ideas?
If this is a RTFM-question please tell me, then I can continue to search for the answer myself.
Otherwise I would appreciate any hint that can guide me towards a solution.
Old   August 18, 2013, 19:55
Retired Super Moderator
Bruno Santos
Hi Alex,
What you're looking for is the filter "Python Calculator" and then you can use the expression:
U/max(U)
Keep in mind that to use the "Python Calculator", you need a ParaView version built-in with Python.
Best regards,
Bruno
Old   August 29, 2013, 03:28
flotus1's Avatar
Alex
Thank you so much.
It took me a while to figure out how to access single components of vectors, but now it works like a charm.
Old   September 3, 2013, 10:23
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi Alex
how could you do that?
@Bruno:
what python code should add in paraview?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   September 3, 2013, 15:08
flotus1's Avatar
Alex
The wiki covers this topic:
http://www.paraview.org/Wiki/ParaVie...hon_Calculator
A common use case in a calculator is to work on one component of an array. This can be accomplished with the following:
Normals[:, 0]
The zero here stands for the first component of the array
wyldckat likes this.
Old   September 3, 2013, 15:33
Ehsan
what's its difference from ordinary calculator filter?is there anything on top of working with components of vectors?
and how can I have a field of area's of cells?
Old   September 3, 2013, 15:59
Ehsan
I used this expression,but that error is shown.
area(inputs[2])
Traceback (most recent call last):
  File "<string>", line 19, in <module>
  File "<string>", line 146, in RequestData
NameError: name 'Normals' is not defined
  File "<string>", line 153, in RequestData
TypeError: area() takes exactly 1 argument (0 given)
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-dev/ParaView-3.12.0/VTK/Filtering/vtkDataSet.cxx, line 405
vtkUnstructuredGrid (0x51fcb80): Point array result with 1 components, only has 37800 tuples but there are 77440 points
IndexError: list index out of range
Old   September 7, 2013, 11:51
Bruno Santos
Hi Ehsan,
area(inputs[2])
If should be:
area(inputs[0])
Best regards,
Bruno
edit: Further discussion on this topic is being done here: http://www.cfd-online.com/Forums/par...alculator.html
Old   August 6, 2018, 06:48
Default rescaling axes grid while displaying contours or vectors
vidyadhar
vidyadhar is on a distinguished road
Hi Bruno,
I want to show temperature contours in paraview.
But, I want to display re-scaled or non-dimensionalized axes.
I tried in using 'x axes custom labels' under 'Axes Grid'. But I am unsuccessful.
I request you to help me how to do this.
Thanks in advance!
Last edited by vidyadhar; August 6, 2018 at 06:49. Reason: title was not included earlier
vidyadhar is offline   Reply With Quote
Old   August 17, 2018, 16:28
Bruno Santos
Quick answer: If I understood you correctly, the trick is fairly simple: apply the "Transform" filter to the "contours" entry in the "Pipeline Browser". The idea is that you need to physically apply the offset position to place the 3D object where you want it and then also apply scale factors to it. You may need to apply 2 "Transform" filters, one hanging to the other, so that you can first do one operation and then do the other one.
Old   August 18, 2018, 05:35
vidyadhar
Thank you Bruno,
I could re-scale my coordinates using Data Scale option under Data Transform in the Axes Grid available under View(Render View).
Thanks for your reply too.
[OpenFOAM] Paraview doesn't seem to be picking up data generated by icofoam MikeHersee ParaView 2 January 6, 2015 08:27
Data Produced From Fine Marine Cant Match with The Experimental Data PeiSan Fidelity CFD 4 August 23, 2014 05:33
Problem running in parralel Val OpenFOAM Running, Solving & CFD 1 June 12, 2014 02:47
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
