[General] Python Programmable vtkImageData
Like Tree4Likes
  • 2 Post By wyldckat
  • 1 Post By wyldckat
  • 1 Post By joshuawd
Old   June 6, 2014, 16:01
Default Python Programmable vtkImageData
Joshua Welch
joshuawd is on a distinguished road
I am trying to write a Python programmable filter that converts point data to a structured grid (i.e., vtkImageData). There is example code here that allegedly does this: http://www.paraview.org/Wiki/Python_Programmable_Filter
(see the "Changing Data Type" section). I opened a new Paraview 4.1.0 file, added a sphere source, applied an elevation filter, then applied a programmable filter, selected "vtkImageData" as the output type, and pasted in the code from the above link. However, when I tried to use this code I ran into 2 problems. First, there were a couple of errors (likely because the code was for an old version of Paraview). Second, when I figured out how to correct the errors (see my corrected version below), the filter produced no data. I am at my wits' end as to why this simple code is not working. Any help you can provide is much appreciated.
Thanks,
Josh
#this example creates an Nx1x1 imagedata output
#and populates its cells with the point centered
#scalars of the input dataset
#get a hold of the input
pdi = self.GetInput()
numPts = pdi.GetNumberOfPoints()
#create the output dataset with one cell per point
ido = self.GetOutput()
ido.SetDimensions(numPts+1,2,2)
ido.SetOrigin(-1,-1,-1)
ido.SetSpacing(.1,.1,.1)
ido.AllocateScalars(vtk.VTK_FLOAT,1)
#choose an input point data array to copy
ivals = pdi.GetPointData().GetScalars()
ca = vtk.vtkFloatArray()
ca.SetName(ivals.GetName())
ca.SetNumberOfComponents(1)
ca.SetNumberOfTuples(numPts)
#add the new array to the output
ido.GetCellData().AddArray(ca)
#copy the values over element by element
for i in range(0, numPts):
  ca.SetValue(i, ivals.GetValue(i))
joshuawd is offline   Reply With Quote
Old   June 8, 2014, 11:23
Retired Super Moderator
Bruno Santos
Greetings Joshua and welcome to the forum!
Well, this is a bit sad... this example you're trying to follow from the wiki page was apparently last tested with ParaView 3.3.1, according to the images; and according to the wiki page history, this example has not been updated since then, and it's not the only example.
I've even tried with ParaView 3.6.2, in hope that this would help make the transition from the old version to the newer versions of ParaView, but it doesn't work with 3.6.2 either.
I'll update this post as soon as I can figure out how to fix this. My first guess is that the object of type "vtkImageData" is the one that isn't being properly set-up for proper use in this filter and the first place I'm looking for answers is here: http://www.vtk.org/doc/release/5.10/...ImageData.html
Best regards,
Bruno
edit: So here's what I've figured out:
  1. The following code works on ParaView 3.12.0, using a "Programmable Source":
    numPts = 1000
    ido.SetWholeExtent(0,numPts,0,1,0,1)
    ido.AllocateScalars()
    ca.SetName("MINE")
      ca.SetValue(i, i)
  2. But a similar code will not work on ParaView 4.1.0, namely this one:
    numPts = 1000
    ido.SetExtent(0,numPts,0,1,0,1)
    ca.SetName("MINE")
      ca.SetValue(i, i)
    ido.GetCellData().SetScalars(ca)
    From what I can figure out, the pipeline is broken for the "vtkImageData" option in the "Programmable Source" and probably in the "Programmable Filter" as well.
edit 2: It looks like my hunch on the pipeline being broken was half right. The following code is needed in the section "Script (RequestInformation)" in the "Programmable Source" on ParaView 4.1.0:
from paraview import util
 numPts = 1000
 util.SetOutputWholeExtent(self, [0,numPts,0,1,0,1])
edit 3: Yep, the information on edit 2 solves the issue on both situations, namely for both the programmable source and filter. I've updated the wiki page accordingly: http://www.paraview.org/Wiki/Python_...ging_Data_Type
elvis and joshuawd like this.
Last edited by wyldckat; June 8, 2014 at 13:21. Reason: see "edit:", "edit 2" and "edit 3"
Old   August 15, 2014, 10:26
Joshua Welch
Thanks very much for your help! That code works beautifully. What I'm really trying to do is create a programmable source that will load image data from a file. I can successfully parse the file, and the image data grid shows up correctly, but the scalar array that I want to use to color the data does not show up. Here's my code, and I'm attaching an example file that I want to load. I'm at a loss as to why this code is not working, since it's nearly identical to the programmable filter code that you posted.
Thanks,
Josh
 def RequestData():
    numPts = 10
    # On ParaView 3.8 to 3.12
    #ido.SetWholeExtent(0,numPts,0,1,0,1)
    #ido.AllocateScalars()
    # On ParaView 3.98, 4.0 and 4.1
    ca.SetName("InteractionFreq")
    f = open("test_file.txt")
    i = 0
    for line in f:
        for pos,word in enumerate(line.split("\t")):
           if pos == 0:
             chr = word
           if pos == 1:
             x = float(word)
           if pos == 2:
             y = float(word)
           if pos == 3:
                ca.SetValue(i,float(word))
                #print "x " + x + " y " + y + " value " + float(word)
        i += 1
def RequestInformation():
    # This part of the code is to be placed in the "RequestInformation Script" entry:
    numPts = 10
File Type: txt test_file.txt (290 Bytes, 3 views)
Old   August 17, 2014, 14:29
Bruno Santos
Hi Joshua,
You're going to find this hard to believe, but the error is pretty simple: "def" is not necessary when defining a programmable source, nor programmable filter. The following worked for me:
  1. Output Data Set Type: "vtkImageData"
  2. Script:
      numPts = 10
      i = 0
      for line in f:
          if pos == 0:
            chr = word
          if pos == 1:
            x = float(word)
          if pos == 2:
            y = float(word)
          if pos == 3:
            i += 1
            print "x ", x, " y ", y, " value ", float(word)
      f.close()
  3. Script (RequestInformation):
        numPts = 10
And make sure the file is in the same folder where ParaView is running from!
I only did a few minor tune-ups to the "print" line and added a close for the file. In addition, improved the indentation of the source code, so that it would be consistent. Keep in mind that Python is very sensitive to indentation.
Best regards,
Bruno
Old   August 18, 2014, 09:33
Joshua Welch
Bruno,
Thanks for the reply. Unfortunately, the code you posted gives me the same results I was getting before. The data loads into Paraview, but the issue is that I want to color the image data by the value of field 3 (i.e., the values stored in the scalar array "ca"). As it stands right now, the only option is solid color. Apparently, for some reason the scalar array is not getting passed through correctly or something.
Thanks,
Josh
Old   August 18, 2014, 15:56
Bruno Santos
Hi Josh,
Did you notice the option that is selected for "Representation"? Change it from "Outline" to "Surface" and then check if it's possible to represent the new array.
Although it's strange that it selected "Outline" by default... ParaView usually only does that automatically when it estimates that the necessary amount of RAM needed for performing the surface representation might be a bit higher than desirable.
If it also does not work, uncomment the line that prints out the values that were loaded from the file. Those values should appear in the "Output Window", which is a new window that ParaView will open to show error messages, as well as other similar messages and warnings. If they do not appear, then the file is not being opened/loaded with success .
Best regards,
Bruno
joshuawd likes this.
Old   August 18, 2014, 16:08
Joshua Welch
...and now I feel foolish. The scalar data shows up just fine under "surface" representation. Thanks much for your help!
Josh
wyldckat likes this.
[General] Listing the inputs of a grouped dataset with a programmable python filter in Paraview NadineHS ParaView 3 December 12, 2021 14:54
[General] selected cells in python programmable filter ufocfd ParaView 3 May 30, 2017 10:05
Working with Python: Query of through-plane flow of multiple clips in one plot PedroInvierno EnSight 8 April 10, 2017 09:23
[foam-extend.org] compile error with python characteristic activated shuoxue OpenFOAM Installation 1 February 6, 2016 17:05
[OpenFOAM] paraview v4 - building with python - OF2.3.0, PVv4, Python 2.7 aylalisa ParaView 4 June 13, 2014 08:52
