Variable name of turb. intensity
Old   September 5, 2002, 07:05
Default Variable name of turb. intensity
Chatterjee
I want to specify inlet value of turbulent intensity thru' plant.
What is the variable name - can you pl. suggest, whether, EPKE??
Old   September 12, 2002, 00:13
Default WHAT IS EPKE
ROY
WHAT IS EPKE IN PHOENICS.
pL. hELP
Old   September 12, 2002, 06:27
Default Re: Variable name of turb. intensity
Hu
You will have to specify KE and EP for the inlet if you are using k-e family turbulence models. The suggested values for KE and EP can be found in POLIS, or you can use your own values. KE and EP then will be solved by PHOENICS with the boundary conditions specified. EPKE = EP/KE which is a ratio of dissipation rate over turbulent energy, so this may be a measure of the state of turbulence.
Old   September 13, 2002, 01:36
Default Thanks Hu and ATTENTION CHAM
ROY
Thank you Dr. Hu
CHAM should take more care in Polis documentation, each qauntity should be well specified.
Old   September 18, 2002, 03:46
Default Re: WHAT IS EPKE
Short
I posted a similar question a year(ish) ago and got the following response.
EPKE = EP/KE and this ratio provides a measure of the frequency of the large-scale turbulent motion
You might like also to try to search the archives for epke.
Turb models Daniel FLUENT 3 July 14, 2008 04:04
must Turb KE @inlet= Turb KE @ initial condition? Rif Main CFD Forum 0 January 10, 2008 01:49
Influence of turb. intensity at the inlet? Ianina FLUENT 0 December 21, 2005 18:15
Low Inlet Turb. Intensity - SST model not converge Pete CFX 0 November 12, 2005 01:26
v2f turb Model Heinrich Siemens 0 December 20, 2001 17:45
