Defining cell faces in BFC
Old   July 24, 2003, 04:07
Default Defining cell faces in BFC
Olof Liungman
I have for many years pondered how the cell faces in a non-orthogonal BFC grid are defined. This is important when determining whether a particle is inside a certain cell, where the velocity components are situated and what the face area is.
Consider the following example: an otherwise cubic cell has three nodes on its LOW face at Z = 0.0, but the fourth at Z = -0.1, i.e. a little lower than the other three. These four nodes are then NOT on a plane. So how does PHOENICS define the LOW cell face?
One idea that a colleague came up with is as follows. Calculate the "mean" position of the four nodes in question (call it the center position, P). Then draw four triangles, each with its tip at P and bases along the four segments made up of the sides between the four nodes. We now have four well-defined planes (3D triangles), with well-defined areas and a (kind of...) center position P where the W velocity component may be placed.
Is this how PHOENICS does it?
Olof
Old   July 24, 2003, 09:48
Default Re: Defining cell faces in BFC
Rami
Hi Olof,
I also wondered about the same question - i.e., how nonplanar cell faces are dealt with - some years ago. Since I did not find an answer, I bypassed it altogether by FORCING planar cell faces during the (BFC) grid generation, e.g., by pure rotation of a planar grid. This was sufficient for my purposes, but it may be not general enough for your needs.
I hope this helps somewhat, Rami
Old   July 28, 2003, 04:23
Default Re: Defining cell faces in BFC (Att. CHAM)
Olof Liungman
Well, Rami, I suppose we are both eagerly waiting to hear CHAM's answer. Anyone from CHAM reading this? If so, please enlighten us.
Olof
[Commercial meshers] Defining new faces after fluenttofoam conversion mayank OpenFOAM Meshing & Mesh Conversion 3 June 4, 2007 10:13
[Technical] Mapping cell faces to other cell faces doug OpenFOAM Meshing & Mesh Conversion 5 March 30, 2007 02:43
[Commercial meshers] Defining boundary conditions on interior faces melanie OpenFOAM Meshing & Mesh Conversion 9 August 10, 2006 09:52
Defining and assigning a variable to a cell Robi FLUENT 0 July 13, 2005 18:27
Defining a new cell variable Ulrich FLUENT 1 May 25, 2000 16:04
