Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
problem with the export of BC file in Gridgen15.09
Old   July 7, 2006, 13:11
Default problem with the export of BC file in Gridgen15.09
alex
Hello, I am writing form Arizona. When I try to export the Analysis Data (for fluent) I have this message: Could not write Analysis BC file. This message appears only when I have a bloc created with the rotational extrusion. Do someone know how can I solve this problem? Thank You
Old   July 8, 2006, 11:10
Default Re: problem with the export of BC file in Gridgen1
John Chawner
Hi Alex. Based on your description, you have generated a structured (hex) grid via rotational extrusion. Therefore, some of the hex cells have fully collapsed faces and get converted to wedges. That's OK. But one cell topology that currently can't be handled is two adjacent faces of a hex that are both collapsed to triangles. For reference, see Section 17.8.19 of the Gridgen User Manual where topology issues for Fluent export are described and illustrated. (Furthermmore, I assume you're using the latest Gridgen version, 15.09R3, and you're trying to write files for Fluent, not Fluent v4.)
If you'd like to talk to someone about this, please contact our technical support engineers at support@pointwise.com or 888-GRIDGEN.
Hope this helps.
Old   July 8, 2006, 12:33
Juan Riquelme
Id like to know exactly who you are.
Old   July 8, 2006, 12:40
John Chawner
I'm the Gridgen Product Manager at Pointwise.
Who are you?
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
Importing I-DEAS unv file hbetb FLUENT 1 August 10, 2001 13:22
