July 23, 2008, 12:39 |
Gridgen grid sequencing
Is there an easy way of sequencing in Gridgen? If I created a domain with dimensions say 30X40, how can I modify this domain to exactly half the dimensions 15X20 without changing dimensions for each of the connectors.
Thanks |
July 24, 2008, 10:22 |
Re: Gridgen grid sequencing
In the Domains menu, there is a "Redimension Grids" function that will allow you to change the dimensions of a structured domain while keeping it balanced, i.e. it will change opposing connectors simultaneously.
Chris Sideroff |
July 24, 2008, 11:00 |
Thanks Chris. I am aware of this option, I was hoping there was an easier way, something like pick all domains and redimension all the connectors of the respective domains at once.
Thanks again |
July 25, 2008, 12:08 |
I'm not sure quite what you're after ...
The function I mentioned to you previously will accomplish what your desire if all your domains/blocks are connected - you simply change the dimensioning of each of the IJ(K) directions and it will apply to all of the other domains/blocks. If your domains/blocks are not connected or point matched at the interface, you can select all the connectors you want changed and redimension them collectively. I could see how, for the later, that selection may tedious if there were a large number of entities in the display window. Perhaps a simple Glyph script could be written to allow you to enter the NxM values of the domain and apply this to all domains you have selected. I suggest contacting support with your question to see what your options are. Chris |
Standard procedure to check grid quality in Gridgen software | CFD XUE | FLUENT | 1 | March 21, 2011 13:56 |
unstructured grid using Gridgen | prapanj | Pointwise & Gridgen | 5 | April 30, 2008 23:49 |
Grid with icemcfd and gridgen | sjm | Phoenics | 1 | March 16, 2003 07:39 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 16:43 |
