Boundary conditions in pointwise for Ansys Fluent |
November 21, 2011, 03:36 |
[solved]Boundary conditions in pointwise for Ansys Fluent
wuyu
I did a simple meshing in Pointwise as a start point of my learning.
It is half of a pipe. I have chosen the CAE solver as Ansys Fluent, but when I read the case file from Pointwise, it seems there are several inlets, several outlets... I did define the inlet domains (surfaces) together as the inlet in pointwise. Anything need to be done to correct this? I have found a post that mentioned this problem, http://www.cfd-online.com/Forums/ans...onditions.html But it seems the answer is, if I am not wrong, some steps in ICEM CFD. Last edited by seasoul; November 21, 2011 at 22:59. |
November 21, 2011, 13:48 |
#2 | |
Chris Sideroff
Rep Power: 22 |
The most likely reason is that you have not defined all your blocks as a single volume condition (CAE > Set Volume Conditions). In Fluent, a volume condition is known as a zone. If you don't place all of your blocks in a volume condition when you export the Fluent .cas file, it will automatically create one zone for each block. When this happens, you will effectively have your boundary conditions straddling more than one zone, which Fluent doesn't like, and thus Fluent will automatically split them. Which I believe is what you are seeing. Let me know if that fixes things. Regards, Chris |
November 21, 2011, 21:01 |
#3 | |
wuyu
Thanks a lot to Chris. Hope this post will also help other learners like me. |
Boundary Conditions for aircraft engine in Fluent 6.3 | Tareen | FLUENT | 0 | July 20, 2011 00:05 |
PointWise Boundary Conditions | skris2009 | ANSYS Meshing & Geometry | 1 | June 24, 2010 12:42 |
Gridgen's boundary conditions and Fluent | famarcfd | FLUENT | 0 | December 12, 2009 10:00 |
