September 23, 2012, 19:14 |
Problem with Gamma ReTheta-Turbulence-Modell
Ive chosen the kappa-omega-Turbulence Modell and at the next step the Gamma ReTheta as the modell for the transition for a simulation. But when I start it the following error occures: "Gamma ReTheta Transition Model must have valid field function set for free stream edge definition in region Luft" There is no free stream edge in this region or at least I havn't defined one. Has anyone an idea what to do? Thank you for your help in advance. |
September 24, 2012, 13:09 |
John
See this post :
http://www.cfd-online.com/Forums/sta...d-airfoil.html |
Problem in k-eps turbulence code in complex geometry | sontukaku | Main CFD Forum | 2 | December 28, 2010 00:44 |
Turbulence model for mixing problem | nileshjrane | OpenFOAM Running, Solving & CFD | 1 | September 7, 2010 17:48 |
Spray problem turbulence intensity | chris1980 | OpenFOAM Running, Solving & CFD | 0 | July 7, 2006 01:08 |
Problem with LaunderSharma compressible turbulence model wrong formulation | luca | OpenFOAM Running, Solving & CFD | 4 | July 3, 2006 06:24 |
Turbulence problem is dead | John Kim | Main CFD Forum | 16 | June 5, 2000 17:35 |
