matching pressure drop with test set up
Prev Previous Post   Next Post Next
Old   November 13, 2012, 22:43
Default matching pressure drop with test set up
adam
sieginc. is on a distinguished road
I'm running a simulation that has a lower pressure drop than what I'm reading from a similar experimental test set up. In the test set up, there is a fan at the inlet whereas in the simulation the inlet is just velocity with uniform flow. I'm guessing the higher losses in the experiment are due to fan swirl, because all the dimensions between the two are exact. How do I account for the extra DP in the experimental set up caused by the fan? I have tried messing with the turbulence intensity and other settings but that had zero influence.
sieginc. is offline   Reply With Quote
[ICEM] ICEM Scripting Issues tylerplowright ANSYS Meshing & Geometry 33 September 27, 2021 16:35
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
pressure drop jay Main CFD Forum 1 September 24, 2008 09:27
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 10:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
