Periodic Boundary Conditions
Like Tree1Likes
  • 1 Post By triple_r
Old   December 4, 2012, 08:55
Default Periodic Boundary Conditions
anonymous
badger1 is on a distinguished road
I am trying to set up my simulation in Starccm+ and want to use a periodic boundary condition. I have looked at the possible options and there is a symmetry plane but this is not what I want. This gives a solution that is symetric on one of the planes. My solution is not symetric but I want it to be repeated over and over again.
It is a compressor blade on a disc and I want to simulate just one blade and then use a periodic boundary condition to simulate the rest of the blades on the compressor disc.
Does anyone know if this is possible?
Thanks
badger1 is offline   Reply With Quote
Old   December 4, 2012, 16:27
Reza
triple_r is on a distinguished road
You need to use a periodic interface. Select the two boundary faces that are going to be pairs, and create a periodic interface from them. After that you can expand the interfaces, and make the interface a rotational periodic interface and specify the axis of rotation. If I'm not mistaken when you generate the volume mesh StarCCM+ will check the interface to see if the two faces are truly periodic and then populate the angle of rotation.
VBS likes this.
triple_r is offline   Reply With Quote
ribbed channel / simpleFoam / boundary conditions beeo OpenFOAM Pre-Processing 20 July 17, 2013 08:39
periodic boundary conditions fro pressure Salem Main CFD Forum 21 April 10, 2013 00:44
Periodic boundary conditions in 3D Eulerian granular flow simulations dsm FLUENT 4 March 2, 2012 19:04
periodic boundary conditions mranji1 Main CFD Forum 4 August 24, 2009 23:45
Urgent: periodic boundary conditions ck1973 FLUENT 3 July 5, 2006 11:32
