Off drag coefficient
Old   February 21, 2013, 00:15
Default Off drag coefficient
Anonymous 92
jackwabbit is on a distinguished road
Yes, hello, I'm currently working on the numerical analysis of flow around an Ahmed body with a rear slant angle of 35 using Star ccm+. I'm getting a value of 1 for the total drag coefficient when the validated value is around 0.25. I've more or less checked everything so I'm going to go with a error in the mesh. If it's the mesh or not the mesh, any suggestions on what could be the problem?
jackwabbit is offline   Reply With Quote
Old   February 21, 2013, 05:33
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
You can refine the mesh and check the value of drag coefficient. The mesh must be improved until you the drag coefficient become constant.
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   February 21, 2013, 06:02
Anonymous 92
Oh alright, thank you! The force coefficient does become a constant does become constant but just at the wrong value. And yes, I'll work on refining the mesh. Are there any recommended range of values for the mesh size for this case? Since the Ahmed body analysis is a pretty standard one.
Old   February 22, 2013, 02:38
siara817's Avatar
As you said at your first post, the drag coefficient should be around 0.25. Do you use k-omeg?
Good luck
Siamak
Old   February 22, 2013, 07:19
Anonymous 92
Nope. I've been using K-epsilon till now, will try k omega and get back. Which model would you say would be appropriate: the standard model or the SST one?
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 09:22
problem with saving drag coefficient colopolo FLUENT 5 April 12, 2013 10:59
Calculation of Drag Coefficient, Help Please teek22 CFX 1 April 26, 2012 18:41
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 12:19
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
