Hydrodynamic force?
Like Tree1Likes
Old   August 30, 2017, 11:09
Can
Lazarus is on a distinguished road
Thanks for your reply Ping.
I created dynamic pressure as a scalar function($Pressure - $HydrostaticPressureFlatVOFWave.) but i couldn't fully understand how to create cell face areas and multiply that areas by the dynamic pressure. Can you tell me how to do it?
Lazarus is offline   Reply With Quote
Old   August 30, 2017, 11:27
Ping
ping is on a distinguished road
as i said above you create a new vector field function defined as $$Area * $DynPress
this creates a vector field of force on every wall face which you can view in a vector scene and sum in a report in the required axis direction
ping is offline   Reply With Quote
Old   August 30, 2017, 13:47
Can
I did exactly what you said and finally obtained the hydrodynamic force
Thank you very much for your help.
Old   July 24, 2020, 09:27
Default How do you define the radial distance for the moment report?
  #24
A. Mier
arm593 is on a distinguished road
Originally Posted by ping View Post
you need to create your own force and moment reports by creating a special vector field function that multiply cell face area by dynamic pressure ( calculated as shown above by yannaos or your own subtraction of g * water depth from the static pressure)
then sum those face forces to get the total force
and for moments create another field fuction and multiply the face force by the radial distance from each face to the center of a coordinate system and sum that field
You mention a radial distance to a center. Is this defined by a position vector or a simple scalar?
arm593 is offline   Reply With Quote
Old   July 25, 2020, 04:04
Ping
it is a simple scalar
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
New sixDoFRigidBody BC working with laplaceFaceDecomposition Ya_Squall2010 OpenFOAM Running, Solving & CFD 13 April 17, 2013 02:04
calculation of Hydrodynamic force on cylinder kamrul029 FLUENT 0 March 27, 2012 12:38
Force can not converge colopolo CFX 13 October 4, 2011 22:03
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 10:25
