July 18, 2013, 15:27 |
Problems in velocity inlet
shoumo
Rep Power: 12 |
Hello everyone. I am just having some problem with my model. My model is a cylinder (as shown in the figure). It has two different velocity component (one tangential and one radial). Can any one please tell me how can I input them in my model. Thanks in advance for your help.
Zoheb |
July 23, 2013, 09:23 |
siamak rahimi ardkapan
You need to generate a local coordinates at the middle of your inlet and build a field function for each component (in x, y and z directions) of the velocity.
Good luck Siamak |
July 23, 2013, 12:31 |
shoumo
Rep Power: 12 |
Thank you very much for your help. I was trying to follow your suggestions, but still having some problem. I wrote my radial and tangential components as follows: 0.508*(position[2]^0.143 and .292*(position[2]^0.143. I got two errors. first it was not taking the power (^0.143) part. Showing some syntax error. Then when I removed this (although not right), it showed me some different errors.
error: unable to compute field function: radial velocity (radial velocity) Cannot resolve function $${position}: "position" not defined. Thanks in advance for your help. |
July 23, 2013, 15:33 |
For position and scalar properties you should put just one dollar sign.
Please search in the help of STAR-CCM : user defined field function or programming reference. Then you will find out how to write power and so on
Good luck Siamak |
July 25, 2013, 01:48 |
shoumo
Rep Power: 12 |
Thank you very much for your assistance. I will try to use your idea and will let you know definitely.
cylinder domain, velocity components |
Inlet patch problems | martyn88 | OpenFOAM Running, Solving & CFD | 6 | April 21, 2017 18:34 |
Why we normally provide velocity at inlet and pressure at outlet for pipe flow? | p07ip705 | Main CFD Forum | 3 | August 3, 2012 05:53 |
inlet velocity BC | ahsan | FLUENT | 3 | July 22, 2009 04:17 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
