Study of wingtip vortices
Old   January 14, 2010, 11:03
Default Study of wingtip vortices
lorenzo.iovio
rory_the_king is on a distinguished road
Hello!I'm Lorenzo and I live in Vicenza (Italy).
I have to study the wingtip vortices of a flow over the Naca 0012 half-wing rounded wing tip.
The chord of the airfoil is about 1.2 m.
What are the three dimensions of the wind tunnel?
Can someone help me?
Bye Bye
Lorenzo
rory_the_king is offline   Reply With Quote
Old   January 18, 2010, 04:47
Anton Lyaskin
A_Lyaskin is on a distinguished road
It really depends upon what you want to simulate. If you want to reproduce some physical experiment, it will be better to take the same dimensions which were in the actual wind tunnel. If you want to simulate your wing in free unbounded stream... Well, actually in this case you'll have to make some parametric study to check the influence of boundary locations. But usually it's something like this: at least 10 chords away up, down, upstream and to the side from the wing tip, and at least 20 chords downstream. You can also check materials of AIAA Drag Prediction Workshops for recommended domain size.
A_Lyaskin is offline   Reply With Quote
Old   March 1, 2010, 16:43
lorenzo.iovio
I need to reproduce an experimental in wind tunnel!!!
I have a question:how can I export a profile of pressure and temperature of a plane?
I have to reduce the wind tunnel to analyze the wake!!!so I have to import the profile of pressure and temperature of new two planes (the new inlet and outlet).
example:
first wind tunnel (along x axes) from -12m to +36 m
section inlet and outlet 12m x 12m
second wind tunnel from -3m to +12 m
section new inlet and outlet 1m (high) and 1,5m (span)
I have to export the profile of pressure, temperature, velocity ecc ecc
of the first simulation and wind tunnel in the second!!!
How can I do?
Thanks of all!
Lorenzo - vertigo1981
sorry for some errors in my text!!!
Old   March 2, 2010, 02:37
Anton Lyaskin
You can specify your boundary conditions with tables. Unfortunately this issue is not covered in tutorials, but you can start from Command reference - there are examples of different possible tables formats in the TBREAD command description.
Old   March 2, 2010, 05:06
lorenzo.iovio
where can I find the thread?
thanks
lore
how can I cut a plane from a derived part?
if I have an inlet boundary. how can I cut a plane smaller?
thanks
lore
Old   March 2, 2010, 05:56
Anton Lyaskin
Sorry, I've forgot we were talking about STAR-CCM+ Then no tables, you'll have to write a user function in Java, which will apply boundary conditions (probably reading some data from external file first).
Old   March 2, 2010, 06:12
lorenzo.iovio
There is a function tables in star ccm+!
The only my problem is how can I cut a plane of "my" dimension!!!
With a threshold I can solve the problem!!!
Bye bye
lore
Old   September 11, 2013, 21:11
Isaac
isaac1326 is on a distinguished road
I`m facing some difficulty in running a simulation on a wing(3d airfoil) in Star-CCM+. The experimental data isnt matching with my CFD results. I mean, the results are wayoff and my mesh is really good, because I couldnt find any sharp edges on my Cl vs Iteration graph. The face quality of my mesh is also above 0.5. And, Iv tried playing with density and dynamic viscosity coefficient, but I couldnt get the results.
Any help would be really appreciated!
isaac1326 is offline   Reply With Quote
CFD Study of a Diffuser lemat1 Main CFD Forum 9 December 7, 2009 07:45
About grid sensibilty study Fabio Main CFD Forum 0 October 15, 2009 11:23
Study Mario Main CFD Forum 0 August 24, 2009 09:59
counter-rotating vortices inside boundary layer Tandiono CFX 13 June 9, 2006 10:32
signicance of vortices Farjana Main CFD Forum 0 November 28, 2005 02:27
