May 20, 2014, 05:11 |
Prism layer mesher
Rep Power: 11 |
I need to calculate wall temperature, so I need the interface fluid/wall to be thiner, so I need to activate the option in interface fluid/wall: mesh conditions-> Interface prism layer Option-> tick Grow Prism from interface box. The thing is that: when I have two different meshes, 1 for the wall and 1 for the fluid, the 'mesh condition' in the interface fluid/wall disapear!! I give you the pic attached... Thank you for your help |
May 20, 2014, 10:19 |
Rep Power: 24 |
Why are you using two mesh continuums? If you are calculating CHT, you want a conformal mesh, which requires you to use one.
May 20, 2014, 10:38 |
Rep Power: 11 |
If I use juste one mesh, the meshes are two big inside the wall. For exemple, the wall thickess is 7 mm and the meshes are 5cm .. it means that there is only 1 cell inside the wall.
May 20, 2014, 10:56 |
Rep Power: 24 |
You can make the prism layer thickness whatever you want on any boundary or interface, there is no limitation on how many core cells you have because of the prism layer. Even if there were, I don't see how using two mesh continua solves that problem.
Prism Layer (Boundary Layer) Thickness | Peter-27 | STAR-CCM+ | 12 | March 27, 2022 12:25 |
[ICEM] Holes in the prism layer | Airon | ANSYS Meshing & Geometry | 3 | September 12, 2013 06:08 |
ICEM Prism Layer transition between surface with prism layers and one without | TWaung | ANSYS Meshing & Geometry | 2 | October 12, 2009 14:56 |
Trimmer & prism layer | peresah | STAR-CCM+ | 6 | October 6, 2009 14:39 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
