March 9, 2013, 06:19 |
Turbo Wizard
anonymous
Rep Power: 13 |
I am trying to create a linear cascade in Starccm+ using the turbo wizard. There are tutorials for the anular setup but not the linear. To make the turbo wizard work you need inlet, outlet, hub and tip files that specify coordinates however I cant seem to figure out how they work or what they would need to be in order to make my cascade work. does anyone have any experience with a linear cascade using Star as any help would be greatly appriciated. Thanks |
March 11, 2013, 16:24 |
anonymous
Rep Power: 13 |
just incase anyone thinks it is relivant, whenever I try to run the turbowizard in linear mode i get the error message
'Error:SurfaceSectioner::createSection()id not find any intersections with surface. Problem occurred during grid generation.' despite when plotting the coordinates for the hub,tip,inlet and outlet on a drawing package they clearly intersect. thanks |
November 23, 2014, 12:52 |
Dagmara
Just wondering if you've solved this?
I was trying to work with Turbo Wizard, but I keep getting that exact error message and am out of ideas by now... Note: mine is a annular problem. |
linear cascade, turbo wizard |
[GAMBIT] problems with gambit tools turbo | qxtxdy | ANSYS Meshing & Geometry | 0 | October 15, 2010 22:33 |
gambit turbo file format | ventoneac_diana | Main CFD Forum | 0 | April 29, 2010 12:02 |
Gambit turbo problem. | sujan.dasmahapatra | FLUENT | 0 | December 20, 2009 05:21 |
Turbo question | spacewatcer | FLUENT | 0 | May 29, 2009 17:03 |
Problem running FINE Turbo | Michal Vanco | Fidelity CFD | 0 | June 7, 2004 06:58 |
