June 22, 2015, 18:40 |
increasing fluid pressure
marwan
Rep Power: 11 |
i have a sphere divided into two part by a circle and there are two inlets and two outlets for that sphere.the inlet fluid has a low pressure and the outlet has high pressure.my question is how can i increase the outlet pressure without using any boundary conditions. what I meant is using the circle that divides the sphere as a pressor . can one of you guys answer this question?
June 23, 2015, 00:28 |
kris
Rep Power: 11 |
I do not understand your problem. The flow goes from high pressure to low pressure, so in ur case outlet to inlet.
Could you provide more details of what you are trying to accomplish? May be a simple schematic would help. |
June 23, 2015, 12:39 |
marwan
Rep Power: 11 |
thanks for your reply. i sent you a message
June 23, 2015, 12:49 |
the image
marwan
Rep Power: 11 |
this pic shows a part of the geometry ,and also the inlets (low pressure) ,the outlets ( high pressure) and the geometry that divided the sphere which will be use as pressor. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
how to incorporate the temperature of fluid in pressure based cavitation model | arindamsantra7 | Main CFD Forum | 0 | September 23, 2014 10:46 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
