June 30, 2009, 19:21 |
creating a field function
Rep Power: 16 |
I am working on a project where I have to simulate the flow of air through a pipeline. I want to create the velocity inlet profile on star ccm+. How do I implement this function into the program. funktion : -2E-08z^4 + 2E-05z^3 - 0,007z^2 + 1,03z- 4,578 Thanks in advance. Can Last edited by can_yas; July 1, 2009 at 03:26. |
July 1, 2009, 05:37 |
Rep Power: 17 |
(-2*pow(10,8)*(pow($$Centroid[2],4))) + (2*pow(10,5)*(pow($$Centroid[2],3))) - (0.007*(pow($$Centroid[2],2))) + (1.03*($$Centroid[2])) - 4.578
In the above formulation you can also use $$Position[2] instead of $$Centroid[2] is thats what you need. To implement the field function on the boundary Region > Boundaries> Physics Values > Velocity Magnitude (Method > field function) Last edited by SKK; July 1, 2009 at 06:58. |
July 1, 2009, 06:59 |
Rep Power: 16 |
(-2 * Pow (10.8) * (pow ($ $ Centroid [2], 4))) + (2 * pow (10.5) * (pow ($ $ Centroid [2], 3))) - (0.007 * (pow ($ $ Centroid [2], 2))) + (1.03 * (pow ($ $ Centroid [2], 1))) - 4.578
I have the equation changed(red color), ist dies correct? and if I have this equation enter into the program, I get error message "Compiled field function type is not vector " Thanks in advance. Can |
July 1, 2009, 07:06 |
#4 | |
Rep Power: 17 |
(-2 * pow (10,8) * (pow ($$ Centroid [2], 4))) + (2 * pow (10,5) * (pow ($$ Centroid [2], 3))) - (0.007 * (pow ($$ Centroid [2], 2))) + (1.03 * ($$ Centroid [2])) - 4.578 In the pow command variables are separated with commas. Also, no space between the two $$ signs. |
July 1, 2009, 07:41 |
Rep Power: 16 |
Thank you for your effort, unfortunately, does not again.diese equation is a velocity distribution in a Pipe.
I have descriped cylindrical coordinatesystem in the Inlet .it must be the Origin in the middle? Part(Pipe) has a symmetry Plane Last edited by can_yas; July 1, 2009 at 09:03. |
July 1, 2009, 08:30 |
Rep Power: 18 |
Sure that he need to write the E8 as a pow?
Normally it works without this fine?! |
July 1, 2009, 08:53 |
Rep Power: 16 |
I have changed the equation again. -0.00000002 * (pow ($$ Centroid [2], 4)) + 0.00002 * (pow ($$ Centroid [2], 3)) - 0.007 *(pow($$ Centroid [2], 2)) + 1.03 * ($$ Centroid [2]) - 4.578 Unfortunately, I get the same error message again,"Compiled field function type is not vector " Thanks |
July 1, 2009, 09:01 |
Rep Power: 17 |
Have you changed the field function 'Type' to vector?
I don't get this error message. I am using an older version of STAR CCM+. I will check it with the new version later and let you know. |
July 1, 2009, 09:02 |
#9 |
Rep Power: 18 |
Hmm is the function set a scalar?
July 1, 2009, 09:18 |
#10 |
Rep Power: 16 |
No, I have field function 'Type' Scalar. I am using version 4.2 of STAR CCM+. how did they coordinate system defined?
July 1, 2009, 09:23 |
#11 |
Rep Power: 17 |
for vector definition, the three velocity components are described [x,y,z]. I guess in your case it would be
[0,0,-0.00000002 * (pow ($$ Centroid [2], 4)) + 0.00002 * (pow ($$ Centroid [2], 3)) - 0.007 *(pow($$ Centroid [2], 2)) + 1.03 * ($$ Centroid [2]) - 4.578] |
July 1, 2009, 09:27 |
#12 |
Rep Power: 18 |
4.2? You mean 4.02?
In the properties you have the function type. Make a screenshot. |
July 1, 2009, 09:32 |
#13 |
Rep Power: 17 |
July 1, 2009, 09:39 |
#14 | |
Rep Power: 16 |
That is really unbelievable. This works. I am very grateful for their help |
July 1, 2009, 09:41 |
#15 |
Rep Power: 16 |
July 1, 2009, 10:11 |
#16 |
Rep Power: 18 |
@SKK: Maybe you should make a benchmark for this extra pow function
A other way would be to use $Centroid_i (maybe a "cleaner" way). Of cource you need the vector "style" for the velocity I make too much 2D |
November 26, 2020, 08:37 |
#17 |
jas
Rep Power: 5 |
I want to do what OP did but with a parabolic velocity profile inlet. The eqaution would be
v(r) = Vm(1-(r^2/R^2)). What code would i have to implement. thanks |
November 26, 2020, 15:40 |
#18 |
Chaotic Water
Rep Power: 17 |
November 27, 2020, 10:08 |
#19 | |
Madrigal
Rep Power: 5 |
Use this: ${Vm} * (1-(pow(${RadialCoordinate},2)/pow(${Radius},2))) CFD2DXY |
November 27, 2020, 10:18 |
#20 | |
jas
Rep Power: 5 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
