September 4, 2009, 19:03 |
Star CMM+ Meshing
Ramchandra Paudel
I have generated a model using solidworks and export the iges file to star cmm+ However, when I try to generate the surface meshing, i face error saying surfaces not closed Somehow I try and modify the model blindly without understanding what exactly is wrong and face warning while volume meshing saying intersecting surfaces I really cannot locate these. Is there a way to by-pass these errors or overcome them? Thank u |
September 4, 2009, 19:35 |
Can you post any pictures?
September 4, 2009, 19:41 |
Digital_Junkie
SolidWorks is a parasolids-based kernel so parasolids will usually be the most accurate export format. Might get rid of the anomalies you are experiencing. If not, try other formats such as step.
September 5, 2009, 03:34 |
Ramchandra Paudel
i am not too sure if i should upload it onto this site. Maybe I could email u for assistance. Ya, it has a hollow cylinder with hemispherical end protruding into a conical body. I have used surface remesher with polyhedral meshing and prism layer. Will using the surface wrapper solve the problem? Please kindly assist me. Thanks.
September 7, 2009, 06:45 |
OK, if I am understanding you correctly, you are getting these errors while volume meshing. Did you surface wrap your imported CAD file before going onto volume meshing? When you import a CAD file, you generally need to surface wrap and remesh it. then check for any errors in remeshed surface and fix them before you can go on to volume meshing. Volume mesher will not proceed if there are intersecting or pierced faces, free edges, nonmanifold vertices and edges in your remeshed surface. Fix these before moving onto volume meshing.
September 14, 2009, 04:59 |
TonyD
1. try parasolid, it gives less errors with Catia, solidworks, NX
2. enable your automatic surface repair for the surface mesher and do a surface mesh, check for remaining errors if none go ahead and do the volume mesh 3. if errors enable surface wrapper and do the surface mesh, check for errors if none do volume mesh 4.if errors after wrapper, go to representations and right click on your rep, choose surface repair and locate the problem, try the manual repair tools to fix this. 5. If error remains check your parasolid in your CAD package, usually there are options like heal geometry or examine geometry to avoid tiny items, intersections and so on. |
September 14, 2009, 05:10 |
Ramchandra Paudel
Thank you friends. Got it.
September 23, 2009, 02:41 |
try surfacemesher
rajesh
study the tutorials for meshing..
check the surface mesher settings..or try to repair import surface from representation ..which can be seen in the tree |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
multi-region volume meshing on star ccm+ | Mike | Siemens | 6 | November 13, 2006 10:36 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
