Memory Exception Workaround?!
Old   September 14, 2009, 03:34
Default Memory Exception Workaround?!
Maddin is on a distinguished road
I have serveral problem whit creating some meshes because this happens in only one process under windows.
Simulations are splitted because I have more cores but only 32Bit...
Is there a trick to create the mesh on 2 processes? Mesh isn't very big, only 300MB but the task manager shows me that CCM needs much more memory for the volume mesh... and then I get a memory error (bad alloc).
Import mesh looks nice, should I look for some faults?
Maddin is offline   Reply With Quote
Old   September 14, 2009, 04:37
TonyD
bramv101 is on a distinguished road
i would say, check your mesh settings. Maybe there is a decimal point misplaced so your mesh size goes very fine. this is usually the cause of these type of problems.
A good tip is to do a surface mesh with coarse settings and examine results. from there add more detail
bramv101 is offline   Reply With Quote
Old   September 14, 2009, 04:54
The cell size is 1mm, base and maximum. Surface cell size the same. Should I make in coarse?
Maybe I should update to 64Bit...
Old   September 14, 2009, 05:46
TonyD
The actual cell size doesn't tell me much, you should compare it to the dimensions of your part. if your part is 100 meters in diameter and your cells only 1mm then you are going to get a huge model.
Take for base size 5 percent of your main inlet orifice, and leave everything else at default. then try to do surface mesh NOT volume mesh. Check your mesh and if you notice that not enough detail is included, adjust your surface size max=100% and min=15%
If you could post a rough sketch of your geometry and your base dimensions, this would be good to start from
Old   September 14, 2009, 06:23
Ok I will look what I can do.
Dimension isn't very big, 1mm is a little bit to coarse I think.
When I make a corse volume mesh I get problems with rasing the mass flow etc.
Old   September 14, 2009, 16:37
I have checked all my settings. I had a extrusion of my wall. Don't know how it came... but it was set...
Thanks for help.
SIGSEGV: memory access exception shawn123 STAR-CCM+ 14 January 20, 2020 06:07
How to optimize the memory usage when using FEM vasilis Main CFD Forum 11 August 24, 2009 23:57
Memory error? Young CFX 3 September 30, 2008 11:33
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
Run-Time memory conifguration Error Graeme CFX 1 February 20, 2006 23:04
