rotating part
Old   November 13, 2009, 22:02
Default rotating part
shawn
shawn123 is on a distinguished road
hi everyone i have simulated a rotating balde with 300 rpm, model is unsteady with time step,anybody knows how i can annimate t5he acctual motion of the turbine because we have a presentation,i am confused because in the annimation part they don't have such a thing,thanks Shwan
shawn123 is offline   Reply With Quote
Old   November 21, 2009, 18:27
ttl
Todd
ttl is on a distinguished road
I've just been going through this myself. There is a way to do animations however there is no direct way to do animations within STAR-CCM+.
What you do is setup the since you want to animate then change the update policy to Time-Step (Scalar Scene > Attributes > Update > Time-Step).
Also set the file name and check the "output frame to file" box.
Now run the simulation for as long as you want, checking to make sure your getting the scene output files.
Then you should have a series of static pictures that you can use to make an animation with. I've used Windows Movie Maker in the past, not a great program but works well enough.
Remember the frame rate will be dependent on your time step size so if your time step is pretty big then the blade will look like it is going the opposite direction.
Have fun!
Have fun!
ttl is offline   Reply With Quote
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
how to define rotating scheme Amir FLUENT 5 December 22, 2008 16:32
IcoDyMFoam how to define more than one rotating regions naoko_oyama OpenFOAM Running, Solving & CFD 0 November 14, 2008 08:25
Difference b/t rotating wall and rotating domain? Juno Kim CFX 2 February 20, 2007 20:08
about mutiple rotating reference frame lingo FLUENT 0 December 12, 2002 04:13
