December 3, 2009, 03:17 |
Mass Flow Inlet with Velocity specification
Bernard Esterhuyse
Rep Power: 17 |
Hi
I'm using StarCCM+ for a rotating flow simulation. I would like to specify a mass flow inlet boundary. On this boundary, the flow is rotating, and I would thus like to specify a tangential velocity distribution. Is it possible to specify this velocity in addition to the mass flow rate? Best regards Bernard |
December 3, 2009, 23:13 |
JSM
Rep Power: 20 |
I think that in any CFD software, you can't specify both mass flow & velocity in single inlet boundary surface. It is not applicable. Depends upon your mass flow rate or velocity input, another value is calculated by solver itself. If you want to specify tangential velocity at inlet, then use velocity inlet boundary condition and specify tangential velocity. Hope this will help U
With regards, JSM |
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 32 | February 3, 2021 03:37 |
Mass flow inlet compressible flow | richard | FLUENT | 2 | June 1, 2008 11:44 |
mass flow inlet | Mech | FLUENT | 2 | July 7, 2006 07:37 |
mass flow + pressure inlet??? | whai | FLUENT | 2 | June 24, 2003 13:42 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
