association with feature curve
Old   November 17, 2009, 07:47
Exclamation association with feature curve
jsm
JSM
jsm is on a distinguished road
I have one question about surface meshing. I created the surface mesh and tried to improve the quality by remeshing through "Remeshed surface -> repair surfaces" option. I smoothened the some portion of mesh. However after smoothening, mesh association with feature curves was gone (means the shape of the mesh changed. Initially it is in circular shape). Is it possible to reassociate the remeshed edges to feature curve.
With regards,
JSM
jsm is offline   Reply With Quote
Old   November 18, 2009, 23:56
jsm
JSM
Could anybody give suggestions for this? I know that I can remesh once again the geometry. However I want to know any option is available to reassociate the edges with feature curves.
With regards,
JSM
Old   November 24, 2009, 15:37
Aroon
vishyaroon is on a distinguished road
I had a similar problem sometime back and could not get it working. Later I was told that the recent versions of STAR CCM+ have the 'Project to CAD' option which solves this problem. I haven't run into the same problem again, so I guess activating this option helps.
vishyaroon is offline   Reply With Quote
Old   November 25, 2009, 00:15
Ping
ping is on a distinguished road
the mesh process is designed to be an auto pipeline starting with your imported surface. If you need to make major manual changes to the remeshed representation then pipeline is broken. You can delete your imported repr. and just use the remeshed surface, and create new feature curves on this (or export the remeshed surface and import it as a replacement import repr. Or be more careful with your smoothing so that feature curves do not move - they are there to retain features - I wonder why you are smoothing them?
ping is offline   Reply With Quote
Old   November 26, 2009, 05:31
jsm
JSM
Hi Aroon & ping,
Thanks for your comments. I am using star ccm 4.02 version. I checked "cad projection" option in repair mesh area. I couldn't find it. Could you point out the location where is that option.
With regards,
JSM
Old   November 26, 2009, 06:19
sankar sudhan
trotter is on a distinguished road
hi everybody i've to do a flow analysis over a car. so where can i get resources for it ..... i mean how can model the geometry ...?
trotter is offline   Reply With Quote
Old   November 26, 2009, 09:32
SKK
SKK is on a distinguished road
Hi jsm,
in version 4.06 CAD Projection option is in you mesh continua > Reference Value> CAD Projection.
I think in the older version of CCM+ it was in the mesh continua > Models>surface wrap or thereabout.
SKK is offline   Reply With Quote
Old   November 30, 2009, 23:22
jsm
JSM
Hi SKK,
Sorry for delayed reply. I am unable to access this forum for last few days.
I am using 4.02 version. So I could not see the option. Any way thanks for your help.
With regards,
JSM
Old   December 1, 2009, 08:28
SKK
Hi jsm,
I just checked the Help file for version 4.02. CAD projection is in Continua > Mesh 1 > Models > Surface Wrapper
The option is in surface wrapper properties windows. In any case, make a search for it on the help file (or press F1) and you should be able to find it.
Goodluck!
Old   December 1, 2009, 22:47
jsm
JSM
Hi SKK,
Yes. In surface wrapper, cad projection option is available. But I am looking for this same option in surface remesher. Thanks for your efforts.
With regards,
JSM
Old   December 3, 2009, 04:41
SKK
Look for it in Mesh>Reference Values>
If you still can't find it, then as I suggested earlier, have a look at the help file...
Old   December 3, 2009, 23:07
jsm
JSM
Hi SKK,
In 4.02 version, cad projection is not available in Mesh>Reference Values>
But in surface wrapper, cad projection option is available. However I am looking for this option in Representation > Remeshed Surfaces > Repair surfaces >
If it is available in repair surface node, then it is really useful to reassociate the edges with feature curves manually. It is not available in 4.02 verision. I dont know about 4.06. Ok. Thanks for your efforts.
With regards,
JSM
Edges association in ICEM Santiago Orrego. CFX 10 July 26, 2020 11:45
[ICEM] Bunching nodes along a curve siw ANSYS Meshing & Geometry 4 October 14, 2009 17:42
[ICEM] Smoothing a curve lost.identity ANSYS Meshing & Geometry 6 July 13, 2009 05:23
How to maintain spacing along a new curve? KB Main CFD Forum 2 June 5, 2007 16:45
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
